User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 04-30-2008, 09:08 PM
  #183
monocoque
monocoque's Avatar
Profile:  1975 29' Ambassador
San Antonio, Texas
The welder and I got to looking at the outrigger material which is 5x1.75x.190 channel. This is big stuff. We decided to take this back to the steel supplier and replace it with something closer to an 1/8th inch material which would still be larger than the original material and much easier and faster to cut. And lighter.
We also decided to use the original A-frame and coupler which have now been cut out of the old frame and tacked right onto the new one. The A-frame, which is 4 inch tube, also has the forward most cross-member attached and the metal plate that lies behind the lower exterior skin and holds the 7-way connector.
The first photo shows how large the 5 inch channel actually is and you can see why it's probably too big for outrigger material. There is also a photo of the old frame with the A-frame removed. And various photos of the new framing! Moving right along!
ID:	59554  Click image for larger version
ID:	59556  Click image for larger version
Todd
“Twenty years from now, you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines, sail away from the safe harbor, catch the trade winds in your sails, explore, dream, discover, and change habits.”
- Mark Twain
Get rid of these ads... register today, it's FREE
Old 05-01-2008, 06:35 AM
  #184
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada, Colorado
Originally Posted by monocoque
Kip, I'm not familiar with these type screws and washers. What would be the advantage of using them in this case?
The countersunk washer prevents the screw head from pulling through the floor and distributes the load over a greater area. the screws are stronger then any screws bought at the big box stores and have a phillips head, with more threads per inch you would have more thread ingagement in a taped hole.
Old 05-01-2008, 07:05 AM
  #185
utee94
Profile:  Currently Looking...
Austin, Texas
It's looking great, I'm surprised with how fast you and your welder are moving right now. Good news indeed.
I might have missed it somewhere back in the thread, but will you be making provisions for a spare-tire carrier, maybe mounted under the frame just behind the A-frame, or even directly on the A-frame behind the LPG bottle carrier? Seems like now is the perfect time to do so.
Anyway, great progress, keep it up!
AirDreamin'
Old 05-01-2008, 11:01 AM
  #186
malconium
Profile:  1973 31' Sovereign
Portland, Oregon
What about pop rivets?
I wonder if there is an appropriate type of pop rivet available that could be used for fastening down the flooring? I know that I have seen pop rivets with a large diameter head on them. Wouldn't there be some type that would work for this purpose?
Malcolm
Old 05-01-2008, 11:11 AM
  #187
monocoque
monocoque's Avatar
San Antonio, Texas
Malcolm
I'm not sure I follow? The flooring outside the wall-channel will be held with the original type self-tapping screws. Yes? No problem there. Part of this discussion, on the other hand, has been about how to use elevator type bolts through the wall-channel above the tubing without access inside the tubing. Kip's idea to use higher quality screws through a pre-tapped hole sounds pretty good to me. Where or how might pop rivets be appropriate? Doesn't sound very strong?
Todd
- Mark Twain
Old 05-01-2008, 11:15 AM
  #188
monocoque
monocoque's Avatar
San Antonio, Texas
Thanks! Yes, this project is moving quicker than I planned. I hadn't thought about the spare tire carrier. It had been removed from my trailer so I don't have a pattern. I assume I could purchase one of these or fabricate from an existing pattern.
Todd
- Mark Twain
Old 05-01-2008, 02:32 PM
  #189
Aerowood
Aerowood's Avatar
Arvada, Colorado
Malcolm
"Pop" style rivets are available in many sizes and styles. Steel blind fasteners of the size required also require a big phnumatic rivet puller, not the type used to pull olympic rivets and such. They also cost big money.
Old 05-01-2008, 02:36 PM
  #190
Aerowood
Aerowood's Avatar
Arvada, Colorado
I can send you a picture of mine later if you're interested. The carrier is removed from my GT right now and just sitting in the basement.
Old 05-01-2008, 02:48 PM
  #191
monocoque
monocoque's Avatar
San Antonio, Texas
Please do! I'm sure the welder would be thrilled to have another task tacked onto the job. Post 'em here if you like. I'm sure there are others who are interested as well.
Todd
- Mark Twain
Old 05-01-2008, 02:55 PM
  #192
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon, Mississippi
Whoo Hooo - Great Thread! It will be great to keep another Ambassador on the road - keep the updates coming.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 05-01-2008, 03:45 PM
  #193
FC7039
1950 Flying Cloud 7039
Profile:  1950 21' Flying Cloud
Allen, Texas
I too am using the tap and bolt method. If that makes you feel more comfortable. I will also put sealant over the screw. This should help "lock" the screws addition to the lock tite.
On the outside achors, the ones through the channel holding the pan and walls, I will probably use a bolt and nut.
Old 05-01-2008, 07:48 PM
  #194
monocoque
monocoque's Avatar
San Antonio, Texas
5" tube and 4" channel cross-members
Here you can see the rear most cross-member and other cross-members fabricated out of 5" tube. The shorter cross-members which occur at the floor-splices are fabricated out of 4 inch channel. So the floor splices will need to be out of 1" plywood or some other 1" material.
ID:	59620  Click image for larger version
Todd
- Mark Twain
Old 05-01-2008, 08:30 PM
  #195
malconium
Portland, Oregon
I think my Harbor Freight pneumatic rivet puller can go up to a 1/4" diameter blind rivet. Would something larger than that be needed?
Malcolm
Old 05-01-2008, 08:43 PM
  #196
malconium
Portland, Oregon
If you trust self-taping screws to work out in the middle of the floor why wouldn't you trust them to work in the areas where you can not use a bolt with a nut on the bottom? I remember when I took my '73 apart being quite suprised that there wern't any bolts attaching the body to the ends of the outriggers. I also remember just how tight the larger size self taping screws grabbed when I used them in some places on my job.
Blind rivets (or pop-rivets) are another type of fastener that does not require access to the bottom of the frame member. I would be very suprised if steel pop rivets in the range of 1/4" diameter would not have plenty of strength for the job but I defer to someone more familiar with rivet strengths on that issue. It would also be easy to double up on the quantity too.
Lets not lose site of the fact that our Airstreams are not going to flying through the air like an airplane. While the attachements need to be strong enough there is a point beyond which the attachments are way overkill. Just maybe we have passed into that zone with some of our suggestions.
Malcolm
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Dan4odm
vB code is On
Pingbacks are On
how to check for frame rot ? oldvws Repairing/Replacing Floor &/or Frame 28 03-02-2007 07:37 AM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 01:40 AM
"Frame rot" 23' airstream land yacht????? gjkkbberg Repairing/Replacing Floor &/or Frame 5 03-14-2005 05:58 PM
Rot Dr. Mariner Repairing/Replacing Floor &/or Frame 5 04-15-2004 08:25 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
