Old 01-13-2009, 06:53 AM   #1
Marietta , Ohio
Frame Issues on 34'
I am considering a 34' model, is there issues with frame sag/weak frame as with some of the smaller Airstreams. Does anyone know of any major issues with a 34'? I read someplace about weight and balance issues, but I recall that was only on the front kitchen models? Any input would be great. Thanks.
Toothpuller is offline   Reply With Quote
Old 01-13-2009, 07:36 AM   #2
A 34 is a great trailer.
Sag happens when the coach is abused.
Keep the running gear properly balanced.
Make sue "ALL" the exterior gaskets are in very good condition. Keeping exterior water out of the trailer, is a must.
Check the axles out to make sure they are still ok. If the trailer has been parked for an extended period of time, then the axles could be bad.
http://www.inlandrv.com/articles/dur...xle-92001.html
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-13-2009, 07:40 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
See the VAC Frequently Asked Questions and read about the 1969-79 Beatrice period.
5 meter Langford Nahanni
Old 01-13-2009, 07:58 AM   #4
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
Hey Toothpuller,
Are you looking at an older 34' or a new one???
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 01-13-2009, 09:07 AM   #5
1983 34' Limited
I own a 34' 84 Limited (3 axels), it pulls great, the weight balance is better than my 31' 76 Land Yacht. The only problem of tweeking is if when parked its not leveled correctly.
Andy K.
Andy K is offline   Reply With Quote
Old 01-13-2009, 09:15 AM   #6
ts8501's Avatar
2022 25' International
Savage , Minnesota
I love our 34'. It pulls like a dream. I have no frame issues. I have seen some real deals on 34'ers this winter. Good luck!
-Tim
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
34' Limited Issues SilverToy 1989-1992 Limited 20 08-19-2013 02:42 PM
Frame issues 1971 31 footer mustang Repairing/Replacing Floor &/or Frame 2 07-08-2008 12:07 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
buying a 1981 excella - frame issues? Pacerized Repairing/Replacing Floor &/or Frame 25 08-13-2006 08:52 PM
