Old 09-27-2007, 09:15 PM   #1
1957 26' Overlander
Mendocino/Humboldt , California
Question Floor question
I am in the proess of ripping out and replacing my floor. Before I begin, I was wondering whether or not the outer shell sits on top off the current floor or if it frame to frame metal. In other words do I need to remove the outer shell to sucessfully install and plush new floor. Thanks for your help.
-Mike
AirMillie is offline   Reply With Quote
Old 09-27-2007, 09:47 PM   #2
-Mike
The shell sits on top of the floor.
The floor sits on top of the frame.
The shell holds the frame up. When you reinstall the shell, use many bolts, the more the better, especially at the front and rear of the shell.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-28-2007, 04:41 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If you intend to replace the whole floor it is easier to take everything out of the trailer and take the shell off the frame. The frame is built first and the floor is built onto the frame. Then the shell is lowered onto the floor and bolted together. Then the inners are put in. In some cases with just local rot, you can slip some replacement plywood inbetween the frame and the shell if there is not a bolt in that location. The frame should be strong enough to hold up the shell but due to frame rot and some original underdesigning and over use of the older Airstreams, the shell is sometimes used to hold up the rear end of a weakened frame. Newer Airstreams use considerably stronger frames and frame bending is not an issue and now they can even design slideouts into the product.
another floor replacement question durans54 Repairing/Replacing Floor &/or Frame 32 02-01-2007 12:29 PM
Floating Floor/Laminate Question soldiermedic Repairing/Replacing Floor &/or Frame 44 11-05-2006 05:58 PM
Floor Question higgy116 Repairing/Replacing Floor &/or Frame 11 07-19-2006 11:25 AM
1 more question on floor replacement? jperryfly Repairing/Replacing Floor &/or Frame 2 06-15-2004 09:59 PM
Floor support question jeanarlene Repairing/Replacing Floor &/or Frame 1 10-11-2002 10:26 AM
