Old 08-05-2005, 04:05 PM   #1
A-frame cracks
Frame cracked? Abusive use? Nah, you can do anything to the frame of an Airstream.
Don't bet on it.
Heavy duty tow vehicle towing an Airstream trailer without any wheel balancing, can result it severe damage to the frame.
The attached photo show an A-frame, cracked almost in half.
The frames on older trailers should be frequently checked for cracks.
The old frames were channel steel, not boxed steel, therefore they can fatigue must faster.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-05-2005, 04:20 PM   #2
norbert's Avatar
1993 30' Excella
whitewater , north of cheddar curtain
Images: 24
very scary
what years are we talking about?
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 08-05-2005, 04:22 PM   #3
All the years that used channel steel.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-05-2005, 04:32 PM   #4
Janet H's Avatar
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Which years used channel steel?
AirForums Custom Search
Old 08-05-2005, 04:39 PM   #5
greg176's Avatar
Gabriola Island , British Columbia
I know my '61 did.Thanks for posting photo,always interested.It looks like corrosion of the upper chord of the channel played a part in the eventual failure.That is why I opted for replacing my frame.
http://www.airforums.com/forum...t=frame+repair
greg176 is offline   Reply With Quote
Old 08-05-2005, 05:14 PM   #6
greg176's Avatar
Andy, I enjoyed your article in Airstream Life on towing and hope to read another some time soon.
I am currently in the market for a pickup.As I will be building a house on the island I was thinking if an F-250 for hauling.Do you think it would be better for the Airstream if I went with an F-150.
Old 08-09-2005, 05:46 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Several posts of this thread were cut and moved to the Community Forum under towing. The title of that thread is called "Tow Vehicles"
Now we resume the regularly scheduled thread called "A-frame cracks"
Thank you.
>>>>>>>>>>>>Action
Action is offline   Reply With Quote
Old 08-11-2005, 09:28 PM   #8
greg176's Avatar
I used to use the wheel balancer that Andy uses to balance Boeing 737 nosewheels at Nordair.Snap On no longer carries it.If you want to do it yourself here is a helpful link.
http://members.tripod.com/ronkilber//BALANCER.HTM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
