Go Back   Airstream Forums > Airstream Community Forums > Dollars & Cents > Buyer Guidelines
Old 02-10-2008, 04:21 PM   #1
coto de caza , California
Toyota Sequoia
anybody here use a Toyota Sequoia (we have a new 2007) as their tow vehicle? what size AS do you pull? thanks
pdl2win is offline   Reply With Quote
Old 02-10-2008, 04:49 PM   #2
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
I have no experience towing with a Sequoia but I know a fellow who tows a 30 foot Starcraft with with an eariler model Sequoia. Check out his web site at http://www.paushe.com/toyotasequoia.
The Sequoia's 4.7L engine may not sound impressive at first glance, but it's OHC and VVT engine coupled with its 5-speed tranny delivers all the HP and torque of my 5.3L push-rod Yukon, which I've used to tow a 30 foot ultralight myself before trading to our new-to-us 25 foot Safari (which should be a walk-in-the-park in comparison as it's only 200 lbs heavier, 6 feet shorter and much more aerodynamic).
With these SUV's the two things you have to watch out for is not exceeding the GVWR as their cargo carrying capacity (CCC) can be limited and you have to pay attention to the anti-sway hitch system due to the short wheelbase. A Hensley isn't necessarily essential, but it's sure nice to have.
Power wise these SUV's can do nicely - within reason and depending on your expectations (read, it ain't no diesel).
BTW, in comparison, he gets about 10%-20% better mileage (towing and not) than I did because of the Sequoia's smaller displacement engine, but now that I've traded to an Airstream, that should even things up.
Gary
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 02-10-2008, 04:57 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
For a newer Airstream I'd say no problem with a 23'. Lighter older Airstreams from 20-30 years ago can be huge rebuild projects but you could go a couple feet longer with those. Hitch weights for empty trailers are here. Otherwise look for the specifications for new trailers at Airstream, Inc :: Home.
Look for the payload figures in your Sequoia user manual. This number is for a specific trim level and vehicle options subtract from payload capacity. Payload capacity numbers will be tighter restriction than tow capacity or GCWR. Sequoia is an SUV version of a 1/2 ton pickup; as such it has a heavier body than a pickup box, thus less capacity. Note that if your Sequoia trim level does not have a Class III receiver (tow package - 2" square receiver + 7-pin umbilical plugin) that the additional differential for installing one of these must be subtracted from the payload.
An RV trailer tongue weight will almost be 150-200# more than the listed empty trailer weights due to added weight distribution gear right at the hitch, propane in the cylinders and conservative personal loading in the trailer. Subtract the weight of all driver/passengers to be carried, tongue weight, etc from your tow vehicle payload. Stay 15-20% under the listed payload for peace of mind and safety's sake.
5 meter Langford Nahanni
New Sequoia accessory ckeysor Tow Vehicles 30 06-17-2008 01:29 PM
TOYOTA Sequoia Ad Photos clancy_boy Tow Vehicles 3 01-16-2008 05:31 PM
Toyota Sequoia Towing an Airstream SE 23'? leetimes Tow Vehicles 16 09-03-2007 12:32 PM
Toyota Sequoia as Tow Vehicle Thegman Tow Vehicles 12 10-13-2006 11:15 AM
Sequoia as Tow Vehicle, help for a new guy. Foiled Again Tow Vehicles 2 03-23-2006 05:45 PM
