Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 02-05-2016, 12:04 PM   #1
1989 25' Excella
Albemarle , North Carolina
Wink installing two aga size 27 batteries
Step by step instructions for installing new batteries. Have removed old batteries, Thanks
eldin is offline   Reply With Quote
Old 02-05-2016, 01:22 PM   #2
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Someone will get right on that.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 02-05-2016, 02:18 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Eldin,
need more info; battery type?, series or parallel?, battery disconnect switch? Photos would help.
Old 02-05-2016, 02:28 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Just did it on my 87, 25' trailer.
Wear safety glasses.
Unplug the trailer from the electric.
Use a 2x4 or other prop across the tongue to hold the doors approximately parallel to the ground.
Set the first battery on the door in front of the opening.
Use a short wrench (I think 1/2 inch) that is completely covered with tape except for the end being used.
Connect the positive to the first battery and push the plastic terminal cover on the wire in place.
Do the same procedure with the second battery.
Connect the ground to one battery and put the terminal cover in place.
Connect the ground to the other battery and put the terminal cover in place
Carefully slide the batteries into place in the compartment. Make sure that you do not contact the trailer skin with an exposed part of the terminals.
The 27 size batteries are a tight fit in my compartments. Height is just barely sufficient to get them in under the outside skin. Once in they fit fine.
Since the 2 batteries are in parallel the terminals are hot once you connect the ground terminal to first battery so be careful not to short anything to the skin.
installing 4 6 volt batteries on Safari 27 FB The Driver Electrical - Systems, Generators, Batteries & Solar 8 05-12-2012 07:08 AM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-22-2010 11:50 PM
Two plus two cello The Pet Forum 1 09-26-2006 02:00 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
