Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 05-08-2019, 08:36 PM   #1
2015 19' International
Driggs , Idaho
Heat Pump Fan
When turning on the furnace while plugged in to shore power, the heat pump comes on even though the thermostat is on the furnace setting. My understanding is that the heat pump is the primary heat source and that the furnace will only come on when the temperature is below 30 F. This would not necessarily be a problem however, the heat pump fan seems to be on high and the fan control setting on the thermostat does not change the fan speed. This seems to be the case no matter what the temperature setting is (many or just a couple degrees different from the inside air temperature). My question is whether it is possible to adjust the fan speed such that the heat pump is more quiet. We have a 2015 International (19').
Thanks, Eric and Heidi
Blischke is offline   Reply With Quote
Old 05-13-2019, 10:40 AM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Any chance your fan setting is set to "On" rather than "Auto"?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
