Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Full-Timing
Old 12-17-2008, 07:02 PM   #21
cameront120's Avatar
1972 25' Tradewind
All you need now is to string some Christmas lights!
North Vancouver, BC
Old 12-17-2008, 07:13 PM   #22
kidless's Avatar
1964 26' Overlander
Prince George , BC
Send a message via Skype™ to kidless
Yeah, but gotta save on power.
Was too busy saving pipes and awnings. Just noticed that Rhodo is probably going to snap. Better get out there again.
kidless is offline   Reply With Quote
Old 12-18-2008, 08:49 AM   #23
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I was told that so-called "milk-house heaters" put out a lot of heat, and are good for trailers, by a Colorado rancher/RVer. They run on 110 volt. Careful with that awning! otherwise, looks beautiful in your last foto!
tphan is offline   Reply With Quote
Old 12-18-2008, 09:38 AM   #24
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Great pics! I love seeing the new ones at the top of the portal page. Stay warm
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 12-18-2008, 10:43 AM   #25
kidless's Avatar
1964 26' Overlander
Prince George , BC
[quote=tphan;648895]I was told that so-called "milk-house heaters" put out a lot of heat, and are good for trailers, by a Colorado rancher/RVer. They run on 110 volt.quote]
"Milk-house Heater"? I just spoke with a local farmer and he told me the only milk-house heater he knows of is the cow... Should I be parking one of those on my front gaucho? I'll look into that, cause one of my heater quit during the night. As for the 'rare happening', the forecast looks like it isn't going to warm up till after Christmas, so gotta come up with something a little more reliable.Christina
Old 12-18-2008, 11:25 AM   #26
1972 25' Tradewind
Is your forced air furnace not working?
North Vancouver, BC
Old 12-18-2008, 11:31 AM   #27
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 101
I think this is what was suggested Feature Comforts at Lowe's: Milkhouse Utility Heater
Aloha 1500 Watt Milkhouse Heater, Model# 83030 | Heaters | Northern Tool + Equipment
This is a common type of heater and while not as small as a ceramic heater, cheap and reliable. Search for milkhouse heater.
Old 12-18-2008, 11:40 AM   #28
1972 25' Tradewind
Christina, I had very good luck with an oil filled radiotor style heater last year when I was using it to keep the trailer just warm enough to keep the damp out. Once they get started, they maintain a good level of heat without being dangerous to touch.
North Vancouver, BC
Old 12-18-2008, 01:06 PM   #29
kidless's Avatar
1964 26' Overlander
Prince George , BC
No, my forced air has not been working. And where I'm staying,, they preferred me not run the propane heater. Gotta work through that issue. Of course, I need a good alternative for when I'm gone. I'll be away a few days over Christmas, and wouldn't want to run propane anyway. Also, couldn't empty all the water lines with the way I'm set up. Growing pains, and learning everything the hard way. The oil filled radiator heater is great for the room, but doesn't help push heat through the water-line areas. I have gotten a hold of one of those milk-house heaters. Just nobody around here calls them that. All joking aside, I did research it right away. It's basically ugly, big, but does a very good job and is reliable. So that's what I'll use while I'm away. I'll also have someone check my pad everyday.
I am or was confused about full timing Frank's Trailer Works Full-Timing 18 12-31-2007 07:21 PM
banking while full-timing rec Full-Timing 11 07-24-2007 10:38 AM
full-timing njoysrvin Full-Timing 5 06-13-2006 09:20 PM
Full Timing abruce Full-Timing 10 01-29-2005 11:29 PM
I'm off full-timing! zduke4x Full-Timing 10 03-08-2004 10:06 AM
