TV wiring
The 1999 LY 355XL I recently bought has a coax from the antenna to a little box with tv1 and tv2 buttons to feed the antenna input to front and back TV's that is located in the upper center compartment over the dash. You can also feed from an aux input and it has a to and from connection to a vcr, which is not there. My book says there is a cable input back in the generator compartment, and it seems to be there. There is also a coax input on the drivers side front fender, if you will. There are also some wires labeled satellite inside the compartment. Does anyone have a diagram of what hooks up where, or any idea what the front fender input is for? It is just open on the outside of the rv-no cover or anything.
