Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 07-23-2011, 03:15 PM   #1
1999 35' Cutter Diesel Bus w/slide
Rimouski , Quebec
Air brake warning intermittent
When i put my cutter 99 in drive, i have an intermittent warning,my air pressure is OK,I would like to know where is the air brake monitoring switch
landmarc is offline   Reply With Quote
Old 07-23-2011, 06:15 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Are you sure its air? Are the gauges showing low air?
If the park legs are not up. or low in oil, it gives an audible warning?
What level system have you got on there?
Could it also be low coolant warning?
Dave
masseyfarm is offline   Reply With Quote
Old 07-24-2011, 08:18 PM   #3
Rimouski , Quebec
Dave
It is not my system level
I try something,i put my park brake on ,and i go on D, i have the warning,i release my park brake and it's ok
If i am in neutal and i release my park brake and go on D,i have a warning
'Marc
Old 07-24-2011, 08:37 PM   #4
masseyfarm's Avatar
Images: 61
"i put my park brake on ,and i go on D, i have the warning,i release my park brake and it's ok"
YES, THIS IS HOW IT IS SUPPOSED TO WORK!
"If i am in neutal and i release my park brake and go on D,i have a warning
'Marc[/QUOTE]
THERE SEEMS TO BE A PROBLEM WITH THIS ALRIGHT. Check wiring security on the air valves. Poor ground? Transmission connector?
Have you got a schematic for that unit?
I can't help you today to search for the diagram as we have company here.
Yours is a 99 so the manual is available to download on the Airstream site.
Dave
Old 07-25-2011, 12:10 AM   #5
masseyfarm's Avatar
Images: 61
http://service.airstream.com/files/l...8c24bec252.pdf
Your info might be here. However, your problem is probably chassis related and you might have to go to Freighliner for the solution.
http://service.airstream.com/files/l...653fd83d5d.pdf
DAve
Your info is here.
DAve
Old 07-25-2011, 03:21 PM   #6
Rimouski , Quebec
i would like to know where is located the wiring security on the air valves on my Cutter
Marc
Old 08-02-2011, 12:06 PM   #7
Nicholasvolle , Kentucky
Air brake warning buzzer
I have a 99 Cutter diesel, my problem was when I released the air brake in drive the buzzer would not go off, the problem was there is a air pressure switch located in front of the rear wheels attached up in the frame rail to the air brake system, this pressure switch is threaded and wires attach which control the buzzer that is located under the dash, cost of the switch from Freightliner dealer was around $ 70, I installed it myself.
maych is offline   Reply With Quote
Old 08-02-2011, 12:15 PM   #8
masseyfarm's Avatar
Images: 61
Thanks for the update and location of the switch information.
Pictures, part #s, are always good for you own information and a great benifit to others.
Not many attempt their own repairs on the Diesel pushers as they think it is to complicated.
In most cases, just as you have done, it is a task of eliminating, until the problem is traced.
Dave
Old 08-04-2011, 09:16 AM   #9
Rimouski , Quebec
I found it and order the switch-pressure n/o n/c 35,but they have an other on the pipe
I appreciate
Old 08-29-2011, 09:14 AM   #10
Rimouski , Quebec
I replace the switch ,and i resolve my problem
Tanks to all off you
Old 08-29-2011, 09:33 AM   #11
masseyfarm's Avatar
Images: 61
Great!
I was under my Clipper before leaving on this current voyage, and checked the wire security, etc on mine. I have had no problem on this issue yet?
Did you get the heavy rain @ your location with Irene????? Any damage?
Nothing but some short bursts of wind at the farm here in Ottawa.
Dave
Air horns on 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-25-2011 07:49 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
