Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 04-27-2012, 12:49 PM   #1
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Marker lights switch for 2005 LY S/O
I recently returned from the NorCal rally with about thirty twelve 'Streamers, including a couple of moho's this time. Many of the trailers added a switch so they could turn on their clearance lights at night, looked pretty cool, so I want to set this up on my rig.
Has any one here done that yet, and have any simple suggestion about where to hook up & put a switch? If not, I'll get out my meters & start poking around.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
TerraYacht is offline   Reply With Quote
Old 04-27-2012, 12:53 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Do they come on when you switch the light-switch to just the running/park lights? (Just short of turning on the headlights.)
It's different for a trailer, but, unless I am mistaken, you should be able to just turn them on at the dash of a motorhome.
Of course, that would turn on your tail lights too.
Vaughan
Old 04-27-2012, 01:14 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it is a trailer. You can just use a jumper wire and connect the charge line pin and the tail/marker light pin together on the umbilical cord. Of course the UCord must be disconnected from the TV.
I do it quite frequently.
I would recommend only doing it while on shore power because it will put quite a drain on the house battery.
Old 04-27-2012, 03:16 PM   #4
TerraYacht's Avatar
Thanks to an overabundance of caution, turning on the parking lights without the ignition turned on brings forth an annoying beeping to "rmind" me that my lights are on. That would be a problem if we are inside and "home:" very annoying. OTOH, I have been accused a few time of "having the lights on but nobody's home" so that may be a solution.
Cliff & Andrea,
Old 04-27-2012, 04:54 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Not only a problem with the beep but some of the lights are only designed for intermitant duty or using the moving air to cool. Melted light fixtures wouldn't be a plus. I have found a couple of lens of the lights in the storage bays melted due to being left on by PO and a deformed taillight housing.
Old 04-30-2012, 08:33 PM   #6
TerraYacht's Avatar
Thanks, Dave: I'll do a test during the day & monitor the lens temperature with my infrared thermometer. If the temperature rise in the day is okay then it will probably be okay for few hours in the evening.
Cliff & Andrea,
Old 05-01-2012, 06:55 AM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Another option would be to change them out to LED as some in the group are doing.
