Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 05-21-2012, 10:22 AM   #1
aussiebrims's Avatar
1997 35' Cutter Bus Diesel Pusher
Full Time Traveling , USA & Australia
Leveler Jacks Fluid Tank Location
1997 L/Y Diesel Pusher
The jacks down light on dash starts flashing while traveling. The jacks are fully retracted, booklet tells us it is low on fluid.
Our problem, where is the fluid tank? Looked everywhere, unable to find it.
The only info we have is the Power Gear operators manual for Hydraulic Leveler System, but, does not tell where to find the tank.
Any ideas?
Mike
aussiebrims is offline   Reply With Quote
Old 05-21-2012, 10:32 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
The warning is triggered by low oil in the reservoir. Do not over fill, but the oil has to be above the add mark.
http://www.airforums.com/forums/f313...tml#post974025
On my Clipper the tank is in the RR compartment.
Dave
Any ideas?
Mike
masseyfarm is offline   Reply With Quote
Old 05-21-2012, 11:49 AM   #3
Checked the RR compartment, no luck. Still looking, any ideas?
Old 05-21-2012, 12:04 PM   #4
FOUND IT......under front right corner of coach in front of wheel well
Old 05-21-2012, 02:30 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
fill is up to the middle of the threads of the plug when the jacks are up. Big cap nut near the top on the side.
DaveFL is offline   Reply With Quote
