Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 05-12-2009, 11:24 AM   #1
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Heat Temp Control AS LYG 30 S/O
I have a 2005 LY gas MH, 30 ft w/ slide and have noticed that the temp control knob on the dash does not really adjust the temperature up or down, but only turns the flow of radiator fluid to the heater core either on or off. There is no in between. Once the knob is turned up past a certain point, the temperature of the air that comes out into the cabin is just plain hot. I called AS and they said "yep, that's the way they made it." I'm not very happy with that , but, does anyone know of a way to modify this system so that the heat temperature is truly adjustable?
Michigander is offline   Reply With Quote
Old 05-25-2009, 01:25 AM   #2
harold1946's Avatar
Surprise , Arizona
The dash temp.control is a potentiometer which controls an Evans Tempcon valve controling water flow to the heater core. A search at evans tempcon should give you a troubleshooting guide in PDF format, and a parts locator. I have heard of some replacing the system with a ball valve and choke cable set up.
harold1946 is offline   Reply With Quote
Water heater - can't find temp control dano Water Heaters, Filters & Pumps 6 05-04-2010 06:36 AM
heat temp control 2005 LY 30 SO Michigander Mechanics Corner - Engines, Transmission & More... 4 06-15-2009 05:15 PM
Heat exchanger for moisture control? SilvrSausage Roof Vents, Skylights & Fans 3 10-13-2007 01:00 PM
Parallax charger with temp control Pacerized Batteries, Univolts, Converters & Inverters 2 04-21-2007 06:16 PM
