Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 08-23-2006, 06:32 PM   #1
Robfike's Avatar
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia , Alabama
TV Up-grade
Streamers,
I just did an up-grade of our TV's in the 345. The old ones worked ok, but no comparison to the new stuff. We went with Magnavox, great picture, and they have the 12 volt capability.
In the front, it was just a matter of taking out the old RCA, and setting the new Magnavox on the cabinet. On the road, I will just set it on the floor ahead of the cabinet. We gain a new storage bin as well.
In the bedroom, I used a wall mount attached to the back wall of the curb side closet. I made a nylon strap with snaps to hold the TV in place while driving. I drilled a 3/4" hole in the vanity top just under the original TV power and antenna ports. The wires and the hole are hidden by the curtain. I then drilled a hole in the closet wall below the counter top and very close to the curb side wall. I ran the antenna, and power wires from the regular plug in's down through the counter top, behind the drawers, and through the closet wall. I then drilled one more hole behind the TV for the wires to connect to the TV.
I used a Radio Shak 12 volt cord and a 12' coax.
The TV's work great on 12 volt, and if we are on shore power, we can just use the 110 volt adapters that came with them.
The Bedroom TV up on the wall gives my wife a lot more room on the counter top for her stuff.
Easy project, and really makes the interior look more up to date.
I purchassed the TV's at HHGregg for $250.00 each, and the wall mount was another $70.00.
Rob
Name:	AS TV upgrade 002.jpg
ID:	25110   Click image for larger version
Name:	AS TV upgrade 005.jpg
Name:	AS TV upgrade 006.jpg
ID:	25112   Click image for larger version
Name:	AS TV upgrade 007.jpg
Name:	AS TV upgrade 008.jpg
ID:	25114   Click image for larger version
Name:	AS TV upgrade 009.jpg
Name:	AS TV upgrade 010.jpg
ID:	25116   Click image for larger version
Name:	AS TV upgrade 011.jpg
Robfike is offline   Reply With Quote
Old 08-23-2006, 06:43 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Nice
I like this!
Old 08-23-2006, 06:48 PM   #3
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Rob - the new TVs look fantastic. Happy viewing!
Mel
Mel is offline   Reply With Quote
Old 09-11-2006, 02:35 PM   #4
1985 34.5' Airstream 345
Fishers , Indiana
I used the same bracket arm on a 17 inch TV and love it. Nice look. Have you done something to your exterior?? Your exterior picture looks like you polished your 345 since I sold it to you.
Wayne
Wayne Olson is offline   Reply With Quote
Old 09-11-2006, 02:42 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Okay as a moderator I "may" have to change the title of this thread I came here thinking "Hooboy somebody got dem a new truck!" Only to find out it was the audio/video upgrade....
BTW nice looking job on the install
Aaron
WBCCI #XXXX AIR #2495
Old 09-11-2006, 07:02 PM   #6
Robfike's Avatar
2012 31' Classic
Andalusia , Alabama
No, hav'nt not done any polishing. I hate creating extra work. On the Falcon Jets I used to fly, we had polished wing leading edges. I hated even watching the clean-up guys polishing them!
Having said that, I really would like to have my aluminum wheels polished though.
I would like to have some of my clear coat redone, along with all of the gray painted areas.
Maby next year.
Rob
Old 09-16-2006, 11:08 AM   #7
str8strm's Avatar
Tujunga , California
what source for signal?
Are you using satellite or just cable at the places you stay? If satellite what system. We are thinking about a major upgrade to install a permanent dish like trac vision. Any experience with those types of systems? thanks
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 09-18-2006, 06:32 PM   #8
Robfike's Avatar
2012 31' Classic
Andalusia , Alabama
We have 3 sources for our TV viewing. We have the roof mounted antenna, the cable hook-up at the rear, and our portable satalite dish.
When we use the dish, I just connect it to the cable connection at the rear compartment, and use one of our dish boxes from home.
All I have to do is change the "source" cable at my splitter inside the cabinet under our living room TV.
Old 09-20-2006, 03:10 PM   #9
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Saw a new thing being done with flat panel TVs...
They slid in and out of a wall like a sideways toaster.
Was really slick.
Had a pivot you could direct viewing from after it was all the way out.
klattu is offline   Reply With Quote
Do you think I need a coarser grade of Nuvite than G6? 72Blazerod Cleaning, Stripping & Polishing 13 07-02-2006 10:52 PM
Floor Repair and Wood Choice JimmyJames Repairing/Replacing Floor &/or Frame 9 10-30-2005 07:40 PM
June 2004 Midwest Rally is Set! jcanavera Forum Rallies & Meet Ups 698 06-11-2004 06:52 AM
Fuel Grade jaiman Mechanics Corner - Engines, Transmission & More... 18 09-29-2003 06:11 PM
Removing vinyl wallpaper/paint GAS Upholstery, Blinds, Walls & Interior Finishes 19 07-21-2003 12:35 PM
