Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 02-04-2011, 08:16 AM   #21
steveturk's Avatar
1978 28' Argosy 28
Post Falls , Idaho
Thanks for all of the help everyone. I'll get at this again as soon as the weather breaks. There are some inside fixes that can be done until it warms up a little. One great thing about owning a classic Airstream is you never get bored...there's always something that needs attention.
Steve
steveturk is offline   Reply With Quote
Old 02-04-2011, 09:06 AM   #22
Steve
Really?
Thats the quote of the Day!
Old 02-10-2011, 05:09 AM   #23
Kenneth
1987_345's Avatar
1987 34.5' Airstream 345
Waxahachie , Texas
Gets me thinking...Hmmm. Perhaps I should check the level in the reservior before it starts sucking air. Turns out its a little low. Can you tell me what type of fluid this system takes?
1987_345 is offline   Reply With Quote
Old 02-10-2011, 08:48 AM   #24
steveturk's Avatar
1978 28' Argosy 28
Post Falls , Idaho
I believe it calls for GM Power Steering Fluid. The fluid level on the power steering reservoir dipstick shows that it's right where it should be. Also checked brake fluid in master cyl. and it's ok. Belt seems a little loose but not slipping - I'll adjust it and see if it helps. Steering wheel is very hard to turn when shifted into park with engine running. Seems to be somewhat easier to turn when shifted into drive for some reason.
Old 02-10-2011, 08:58 AM   #25
Interested to find what it is Steve!
Mine seems to work fine, but the growing puddle of PS fluid under my 345 and the dropping Reservior level indicates I have a problem!
Old 02-17-2011, 08:36 PM   #26
Pay attention here! You have air in the emergency brake can. When you shift into park, the valve opens that pumps fluid to the emergency brake, lowers the level in the reservoir, and sucks air. When you shift into gear, the valve releases the E brake and that fluid comes back into the system and gives you a little more pressure.
Get under there and get rid of the air in the can so you can fill the system and bleed it, engine off.
Not gonna tell you a 3rd time. Hmph!
fangthorpe is offline   Reply With Quote
Old 02-18-2011, 08:54 AM   #27
steveturk's Avatar
1978 28' Argosy 28
Post Falls , Idaho
I'm going to follow the steps you sent previously as soon as I can...along with checking the belt tension. It's the first thing on my Airstream priority list. The winter has made it a little difficult for the outside stuff and am trying to get some of these fixes done after work. Gets dark before I can get there. It looks like I'll have more time soon and the days are getting longer. Will post how it goes ASAP.
Old 02-18-2011, 05:00 PM   #28
Mine sat for almost a year before I got it sorted. I tried everything. Even the Chevy dealer. I just don't want to see you spend money on parts you don't need or get all bummed out about your rig when it only needs 30 mins of work and some fluid to be fine. Good luck.
310, power steering, motorhome
Progressive Dynamics Inteli-Power 4060 Power Center 68 Overlander Commercial Listings 0 01-21-2011 11:24 PM
84 310 balljoints/brakes mick32 Classic Motorhomes 7 01-21-2011 09:36 PM
Steering Stabilizers LaCajun Land Yacht/Legacy Motorhomes 2 01-15-2011 10:32 PM
1997 Airstream Cutter Class A Motorhome eBay Watch Airstreams on eBay 0 01-11-2011 01:30 PM
1995 Airstream 190 Class B Motorhome eBay Watch Airstreams on eBay 0 01-06-2011 12:00 PM
