06-07-2012, 12:11 PM
1979 28' Airstream Excella 28
Commerce
, Michigan
New to the Forum
Hello everyone I just decided to register after following this forum for a year or so. I find the people here to be most helpful and freindly. I've owned a 1979 28 Excella now for 12 years and have a terminal case of aluminitus just like everyone else here. I've done many of the same repairs and upgrades as many of you have and hope I can be of some help to others here. I work in powertrain engineering for the automotive and trucking industries in Michigan.
Looking forward to being part of the forum
DA TAZ
06-07-2012, 01:06 PM
1984 31' Airstream310
Ajo
Welcome! Your expertise and offer of help is appreciated.
06-07-2012, 01:19 PM
1982 24' Airstream 240
Ventura
Welcome to the forums.
We have a 1982 24' Motorhome that we are in the process of bringing back to a useable motorhome. We have a 454 7.4 L Chevy engine on a P30 chassis.....living in California, we had to bring her back to her original smog equipment.....not an easy task....but we were able to get her smogged and licensed....now we are concentrating on the inside.....if you change this, well we might as well do that......welcome again and please post some pictures...paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
06-07-2012, 02:30 PM
Commerce
, Michigan
I to have a p30 454
My current project is going all electric on the engine cooling fans.
06-07-2012, 03:51 PM
Ajo
You obviously have a 454. Geez, those engines with the crappy manifolds got hot; cook a steak in 3 minutes. I have heard that Banks built a better manifold/ exhaust system that helped.
06-07-2012, 09:49 PM
1986 32' Excella
Canton
, Georgia
Good idea to use it for cooking! I love those old motorbikes... Maybe someday!
1986 32' Excella
Canton
, Georgia
Duh, not bikes!
Um, motor HOMES. Darn autocorrect!!!
06-07-2012, 11:23 PM
1989 34.5' Airstream 345
Silverton
There is a cookbook, probably available at Amazon, titled Manifold Destiny...all about cooking on the engine block while headed down the road...my '63 Chevy fed me a warm/hot meal many times, although I would prefer not to remember the time the can of beans exploded...WHAT A MESS!!! This book informs you of how to foil wrap stuff, where to place it for best cooking, and when to stop and turn it...entertaining reading, even if you don't try it...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
06-08-2012, 08:01 AM
Commerce
, Michigan
I think i'll stick with the BBQ I've done it snowmobiling and i dont like the taste of 10w40
06-08-2012, 09:05 AM
Mantua
, Ohio
Used to do hotdogs on the cylinders of old BMW boxer twins. Jim
06-09-2012, 07:28 PM
Surprise
I was looking through some old paperwork from Airstream and found a letter admitting that on the passenger-side exhaust manifold there was a design flaw that caused the exhaust manifold gasket and doughnut gasket to fail prematurely! This flaw being the Steel Panel in the wheel-well blocking airflow and essentially trapping the hot air. This is for the 310/454ci varient. I'm sure other models as well!
I'm considering notching out a piece of this panel and bending it out to funnel some air to this area. Just thought I'd add my own observation!
06-10-2012, 04:22 AM
Commerce
, Michigan
I have seen that manifold glow cherry before i added a trans cooler which required a large hole thru the wing panel. I also had the radiator redone about 4 years ago and went to 4 cores now even when i tow my boat im lucky if i can reach the thermostat on cooler days. The main reason i m going all electric on the fans is noise. The stock cluch fans can engage harshly and a toss the belts and flex fans are noisey------huh-----
06-10-2012, 04:56 AM
2021 25' Globetrotter
Jamestown
, Rhode Island
Welcome to the forums!
It seems by your post that you have an understanding of mechanical things, good!
It will be interesting to see if you chime in on some of the more "mechanical" debates that sometimes happen here. In general there is a nice group here and the forum is a lot of fun!
Bruce
06-10-2012, 05:40 AM
Commerce
, Michigan
Thank you Bruce B. I see another thread on fridge repair has started. When mine failed 3 years ago i went to a convensional compressor type with an inverter could not be happyer with the preformace. Ill post some pics and duity cycle info soon.
06-10-2012, 06:49 AM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
I suppose that is why they started to add the vents at the wheel well around 85/86
AIR #13
06-10-2012, 07:46 AM
1989 25' Excella
Hobe Sound
Welcolm to the fourms!
Over the years the fourms community of classic MHs have been a great place to share info on all kinds of repairs. I,m sure you have much to share.
06-10-2012, 08:28 AM
1988 25' Excella
Trumbull
, Connecticut
GMC 454 Manifolds
I have a 1989 GMC 3500 dually that is on it's 4th set of exhaust manifolds.
I also have a 2005 Chevy 2500 HD that is on it's 2nd set of exhaust manifolds.
The 454 bolts could all be removed without breaking but the Chevy has a reputation of bolts breaking and exactly half had to be drilled out.
Happy Camping nm1oqrz
06-10-2012, 10:14 AM
Commerce
, Michigan
When i did mine i drilled the mounting holes out to. 437 and used grade 8 12 point bolts with hardened tooling washers and thick copper gaskets ----no problems since in 8 years. When i go to headers ill cut the flanges between the pipes for a little compliance --- works well on the test stand engines at work.
06-13-2012, 06:45 PM
1995 36' Classic 36
Ludington
, Michigan
2X!
Very good indeed. I tell people that there are some very good deals on these older classics but if you can't do the work yourself, they will eat you alive!
If my frig ever fails, it will be replaced with a conventional and inverter.
