Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-11-2007, 10:34 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Looking for source for generator exhaust extension
Hello, I'm hoping someone can help find a source for an extension for the exhaust for the Honda EV6010 installed in my 1984 310 Limited MH.
The generator compartment is located curb-side rear, under the bedroom window. In some cases I have had my CO detector go off when the generator is running. This only happens occasionally when the wind and other conditions are just right. I'd like to get an extension for the exhaust so that it will be directed above or away from the rig. I have seen two kinds of extensions. One has a rigid pipe and mounting hardware which holds the rigid pipe vertically on the side of the rig, the other style has flexible tubing which allows you to direct the exhaust as you like.
It is this latter type I am looking for. Anyone know of an internet or mail order source?
TIA
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 10-11-2007, 10:39 AM   #2
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
A friend of mine took his moho to a local muffler shop, and for $50.00 he had his generator exhaust pipe relocated and extended.
Derek
dnrtheil is offline   Reply With Quote
Old 10-11-2007, 11:12 AM   #3
guy99's Avatar
Images: 16
Thanks for the suggestion and I will check with the local muffler shop. What I'm looking for is something I can attach to direct the exhaust (and its sound) away from the rig when I'm parked, then remove and stow while I'm under way. Perhaps the muffler shop can fab something like that for me but I have seen kits on other rigs.
Derek
Old 10-11-2007, 02:15 PM   #4
Central , Mississippi
go to the Camping World web site, RV Generators, accessories. I think they have a couple of items you might like.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 10-11-2007, 03:24 PM   #5
guy99's Avatar
Images: 16
Thanks. Did you see the flexible type on the Camping World site? All I saw was the rigid sort.
Old 10-11-2007, 04:33 PM   #6
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I did a google search, this is one of many options I found. I believe I've seen it at the hardware store as well. Good luck.
Dave
FLEXIBLE EXHAUST TUBING - FLEXIBLE - JCWhitney Truck Parts
Fyrzowt is offline   Reply With Quote
Old 10-11-2007, 04:35 PM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You can buy orange flexible silicone ducting by the foot. It'll handle exhaust fine.
You can check McMaster-Carr
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 10-11-2007, 06:31 PM   #8
If you add some flex tubing be careful it get ungodly hot! I used some on a genset and getting closer than a few inches results in a burn. 10x worse than standard exhaust tube
Old 10-23-2007, 04:30 PM   #9
Lido&Linda's Avatar
1985 34.5' Airstream 345
Chino , California
gen exhaust
there is a device valled venturie.but you can make your own just a pipe going up pass your roof attach it to your pipe with an air gap hot gases go up.
The Unleaded Zeppellin
Lido&Linda is offline   Reply With Quote
Old 10-23-2007, 04:42 PM   #10
Lido&Linda's Avatar
Chino , California
gen exhaust
Sorry wrong name its called gen-turi
Old 10-23-2007, 11:39 PM   #11
guy99's Avatar
Images: 16
Thanks, the problem with the gen-turi for my application is that it would interfere with opening the awning.
Old 10-24-2007, 12:24 AM   #12
Streamline Imperial
SilvrSausage's Avatar
Bellflower , California
Lightbulb
Ask the exhaust shop to bid on running the pipe over to the other side, then. Depending on what equipment is already there, it could be inexpensive... pipe is cheap as long as complex, labor-intensive bends needn't be made. Also ask about another muffler along the line, since the noise is bothersome to you; a long pipe gets boomy sounding, even downstream of a decent muffler. Any such device must be BEFORE any type of venturi-coupling. A really good exhaust shop could make you a permanent, unique pipe to the roof, too... perforated stainless guard, anyone? Airstream shaped brackets, maybe? OTOH, that would not be good for aerodynamics, going down the road, unless your genset is toward the rear and the pipe could run up the back. Or even just point it out under the bumper like the engine exhaust, fewer openable windows back there usually.
I always wondered about windage and generators... now I know, the fumes from that extra little exhaust pipe DO blow in under some conditions.
It seems I love the mountains and deserts more than my friends do. I sure miss them!
1971 Streamline Imperial project "Silver Snausage", 1985 Coleman tent trailer, 1964 Little Dipper, 1975 Northwest "Proto Toyhauler", 2004 Harbor Freight folding, still seeking my Airstream.
SilvrSausage is offline   Reply With Quote
Old 10-29-2007, 03:53 PM   #13
I was told by my RV guy that the exhaust had to exit at a location that was not below any slide or window, I guess with the CO that migh help prevent problems since the warm exhaust will rise.
Step Extension Storage Ganglin Steps 3 10-01-2007 09:52 AM
Help with extension cord size bgarrison Electrical - Systems, Generators, Batteries & Solar 11 08-26-2007 08:54 PM
Hitch extension Phil Gobie Hitches, Couplers & Balls 26 12-05-2006 02:54 PM
Onan Generator Exhaust Pipe swebster Mechanics Corner - Engines, Transmission & More... 1 04-20-2005 07:16 AM
Receiver Extension bugdoc 1997 - 2004 Bambi 10 11-17-2004 04:41 PM
