Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 08-19-2016, 01:10 PM   #1
RBonney's Avatar
1983 27' Excella
1990 34.5' Airstream 345
Spring Lake , Michigan
Laser cut ignition (key) switch tool.
I'm hoping this solves the problem of my key set coming loose again. I had this laser cut for me this week. I used a 10 mm socket to tighten it. Seems to be real right now let's see if it stays that way. Click image for larger version
Name:	ImageUploadedByAirstream Forums1471633694.926878.jpg
ID:	269475Click image for larger version
Name:	ImageUploadedByAirstream Forums1471633705.714008.jpg
RBonney is offline   Reply With Quote
Old 08-19-2016, 05:45 PM   #2
I'm not sure I understand what the triangular piece is for
1975 24' Argosy Motor Home
Old 08-19-2016, 05:49 PM   #3
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I get it. Toward the end of our last trip I went to start the 310 and no love, the entire switch was turning clockwise with the key. I had a pair of channel locks and was able to tighten the bezel so that the switch stayed put and worked again. The triangular piece would do a better job than the channel locks.
Waipio Rim is offline   Reply With Quote
Old 08-19-2016, 06:12 PM   #4
Ok, that makes sense!
Pretty ingenious idea
Old 08-19-2016, 07:23 PM   #5
RBonney's Avatar
1983 27' Excella
When I get my laser cut bill I'll let everyone know how much it was and I order more. I'm keeping mine in my glove box.
Old 08-20-2016, 06:39 AM   #6
Count me in
Laser Rust Removal bganso General Repair Forum 8 03-15-2016 06:42 PM
Part number for Argosy MH ignition key blank? martin300662 Argosy Motorhomes 8 07-31-2015 11:22 AM
Lost ignition key, best solution? SteelyDan Classic Motorhomes 8 10-24-2012 07:21 PM
Laser Airstream OB Bambi Airstream "In the News" 2 10-11-2009 04:02 PM
Key Stuck In Ignition doorgunner Mechanics Corner - Engines, Transmission & More... 26 11-12-2006 07:17 PM
