I've yet again come across another unavailable part. Anybody have an extra or a suitable replacement? I need GM# 01601022, overflow bottle for my 310. I'd like the original so I don't have to change mounting holes and still use the low coolant sensor.
The broken pieces on ours fell into the tank. Epoxied them back in place, and the tank is back in service. If the pieces had been missing, I woul have looked for something in the kitchen to cut up for a patch. Not pretty, but it works.
Most auto parts have generac tanks. Inexpensive and works great! You can drill holes for the sensors for the low level on the dash. The last GM tank I put in only got me 6 years and you have to drill them to.
I replaced mine with the O'Reilly generic tank. They have two sizes and I used the larger of the two. I absolutely could not justify the overpriced original tank. I've done a half dozen trips now and the O'Reilly tank works just fine.
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
