Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 07-01-2010, 09:57 AM   #1
Pointes aux Outardes , Quebec
Best diesel motor/tranny
Which is the best diesel engine and tranny to put in A20
YeKo is offline   Reply With Quote
Old 07-02-2010, 06:36 AM   #2
Please help me because i want to by a Argosy 1975 20' with a 350. A diesel engin dos it fit .
Excuse my english I french Quebecer !!!!
Old 07-02-2010, 01:20 PM   #3
2010 27' FB Classic
N/A , Texas
Since your not getting an answer, you may have to ask the same question on a truck forum. You mentioned a 350 I assume it is a Chevy chassis? I don't know what an A20 is. I'm not sure there is an easy swap from a gas engine to a diesel without a lot of frame work and mounting options on any model.
Maybe the best place to ask is DieselPlace.com. There are lots of gearheads on that site who may know.
I like the preformance of the 6.6L Duramax diesel mated with the Allison automatic 6 speed trany in my pick up truck. It is everything I want from an engine and trany.
Good luck finding your answers.
Old 07-02-2010, 02:20 PM   #4
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
Keep in mind that the medium duty diesels are much heavier and somewhat larger than a gas V8. While such swaps are doable for skilled someone who's a skilled mechanic and fabricator and understands modern vehicle electronic control systems, it's a major project. Expect extensive work on other parts of the vehicle, including the cooling, exhaust, electrical and fuel systems. A successful approach will probably require more research, planning and design time than shop time.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
1994 diesel land yacht motor home frankf Mechanics Corner - Engines, Transmission & More... 4 06-30-2010 07:26 AM
Need PHX (or Tucson) engine/tranny shop referral for 81 turbo diesel silverback Mechanics Corner - Engines, Transmission & More... 9 08-21-2009 02:30 PM
1982 Airstream Turbo Diesel 28' Motor Home condnn Buyer Guidelines 3 04-05-2009 02:17 PM
Airstream 280 Turbo Diesel Motor Home eBay Watch Airstreams on eBay 0 03-01-2009 08:20 PM
Need Help looking at 28' diesel motor home SteveR Airstream Motorhome Forums 1 02-01-2004 06:46 PM
