Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 02-16-2012, 10:09 AM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
'76 Argosy MH Doghouse Removal
FYI - Posting for reference
I've read that that 80's motor homes have a doghouse you can remove. I'm in the process of trying to get the radiator out and changing belts on a '76. Even with the dog door up I could not easily access the belts or anything on the front of the engine. The pictures below document what is required to get the complete door removed. Overall it wasn't that bad. There are 8-10 metal screws that hold the metal door on. Mostly from the outside in. The original carpet has a piece that was made for removal of that area. When I re-carpet the front I will come up with a better design. I plan to install the screws from the inside when I re-install it.
Removal of the door actually makes working on the front on the engine possible.
ID:	151235   Click image for larger version
ID:	151237   Click image for larger version
MrJ is offline   Reply With Quote
Old 02-16-2012, 11:21 AM   #2
WineStream's Avatar
2023 30' Globetrotter
Pleasanton , California
Images: 24
Amazing how they changed things from one year the next... I am currently in process of doing the belts on my 77 and I removed the while doghouse as well, but the detachment procedure is much easier. The firewall area its vastly different geometry on mine which is only one year newer that yours.
WineStream is offline   Reply With Quote
Painting the 1977 Argosy Motorhome Roof Gill L Roof 4 08-06-2013 07:53 PM
Looking for 2 speakers (or covers) for '78 Argosy KAYAKAMPERS Audio, Video & TV 11 01-06-2013 10:08 PM
'76 Argosy MH Doghouse Removal MrJ Argosy Motorhomes 1 02-16-2012 11:21 AM
1973 Argosy -typical recovery mission robandzoe All Argosy Trailers 5 02-15-2012 08:31 AM
1988 argosy airstream 33 foot eBay Watch Airstreams on eBay 0 02-12-2012 05:40 PM
