Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 08-21-2014, 09:36 PM   #1
1987 32.5' Airstream 325
Windsor , Ontario
12 volt fuse box
I have a 76' Argosy MH 24 foot. Trying to trouble shoot my water pump but on-board power does not seem to work.
Where is the fuse box for that service?
Thanks in advance,
Chris
realpank is offline   Reply With Quote
Old 08-22-2014, 05:33 AM   #2
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
In my 76 Argosy 24' moho the fuse box is located in the back on the drivers side under the bed. There should be a wire that runs up to the switch and then back to the water pump in the rear. In the off chance that something is wrong with your fuse box, I have a spare.
mprokop87 is offline   Reply With Quote
12 volt
can't find 12 volt fuse box on 1988 32ft. excella charleshanse Member Introductions 1 05-08-2012 08:14 AM
12 volt fuse box matilda Electrical - Systems, Generators, Batteries & Solar 2 06-27-2006 09:00 AM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
