07-06-2018, 05:29 PM
2022 25' Flying Cloud
NCR
, Ontario
Bumper install -22FB
i have installed the 22FB bumber kit
i ordered it from canam (london ON). it took 3 months as AS factory kept delaying the order
the documentation , as usual, does not list all step or details
if you are handy, you can get it down in 1/2 day with one person
07-07-2018, 05:59 AM
2018 22' Sport
eden prairie
Wow nice addition! I bet with your solar additions it’s really getting that custom look. Can we see a few more shots from further out?
2018 Sport 22fb
Ford Transit 250 Quigley 4x4
Gitchee Gumee on the Keweenaw Peninsula
07-08-2018, 06:12 AM
2017 22' Sport
edison
, New Jersey
I've been researching for the rear bumper. Why does the bumper extent out so much. Is there a storage in that area?
2017 Ford Expedition EL
2017 Airstream 22FB Bambi
07-08-2018, 06:22 AM
NCR
, Ontario
Yes, Its storage. we with keep the bulky items in it
you have the option of removing the storage and the bumper would be much closer.
given the limited storage already, i need it
07-08-2018, 02:31 PM
NCR
, Ontario
if you plan to install a bumper, you should tap thread into the bumper posts as the metal is hard. AS does not mention this , but if you don't, you wont be able to get the bolts in
here are the final looks.
we filled the bumper area with our bulky power cables.
here is are cleaned , lit curb side storage area and we moved the fresh water hoses to a shelf i build atop the gas cans
07-08-2018, 04:42 PM
2018 22' Sport
eden prairie
The bumper and the solar seem to complement each other and provide balance.
2018 Sport 22fb
07-10-2018, 10:09 AM
2017 19' International
2018 25' Flying Cloud
Monrovia
I don’t find the bumper to be water tight, you may want to reverse the contents of your storage areas, leveling bricks and sewer parts are waterproof not so with electrical connectors.
07-10-2018, 02:22 PM
NCR
, Ontario
no, its not water proof.
i added extra holes in the bottom so that water flows out easier.
the power cables are very bulky and so were the fresh water lines.
that's why i looked for new homes for them
08-13-2018, 06:18 PM
NCR
, Ontario
today i installed TWO locks with Cam Lock Dust Cover
i used
15 Ton 1/2" to 4" Hydraulic Knockout Punch with
double D punch die
10-03-2021, 09:07 AM
2022 20' Bambi
Genoa
Did the bumper bolt on, did you have to drill holes?
10-03-2021, 09:59 AM
2019 22' Sport
Port Coquitlam
, British Columbia
Hi Waninae,
The bumper certainly gives the trailer a ore complete look. Whenever I look at ours, it feels unfinished.
Is the bumper kit a typical kit? I am thinking that it is a bit wider than the Sport’s narrow width but more in line with the wider Bambi’s at 8’-0”. It is hard to tell from the photo.
Anyway, it looks great and you have more storage and more protection.
Peter.
"Live Long and Prosper \\//" - Spock
01-22-2022, 11:13 AM
2019 25' International
Tyler
Do you happen to still have your instructions for the install? Before I order one, I would like to read them over. I am very handy so I don't think this is an issue for me to install, but I would like to look it over. The deal want's $1000 to install it.
01-22-2022, 04:24 PM
2008 27' International FB
Venice
Rear bumper install.
Am I to believe there was no bumper in the rear? If so, is this Canada thing?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
01-22-2022, 06:45 PM
2019 22' Sport
Port Coquitlam
, British Columbia
The Sport models didn’t come with a rear bumper. I think the Bambi models are coming that way as well.
Peter.
01-22-2022, 07:08 PM
2017 16' Sport
N/A
, N/A
I believe it’s the Caravels that are factory with the rear bumper both 16’ and 22’
02-07-2022, 08:43 PM
2019 22' Sport
Kodiak
, Alaska
This is great, I didn't know you could get an aftermarket bumper. I'd been looking for a way to add a bike rack to my 22' Sport. Thanks for sharing!
02-08-2022, 06:43 AM
2004 22' International CCD
Beaumont
Looks great!
We keep our waste water dumping hose and fittings in ours, since it keeps those things outside and no one is likely to steal them.
On our 2004 22’ CCD, the rear window is an emergency escape route in case of fire, so we won’t be placing a solar panel there (although it does look nifty!). I would be worried that a park ranger/ officer or border agent might be able to deny us usage of our camper until that barrier was removed, as well.
05-27-2022, 07:51 AM
1973 25' Caravanner
Palmer Lake
Do the bumper rails attach to the C channel skids beneath the belly pan? Or do you have to remove the belly pan and attach the bumper rails to the frame members? Thaks
06-01-2022, 03:46 PM
2019 22' Sport
Margaritaville
My understanding is that the bumper members slide into the frame box tubes. You have to cut out holes in the black plastic banana wrap concealing the box tube ends. You drill pilot holes through the frame and into the bumper member for the supplied self tapping screws. I’ve read of some installers using tapped holes for hex bolts instead of using the self tapping screws. After installation, caulk around the seam where you cut the holes in the banana wrap.
This thread may be helpful. https://www.airforums.com/forums/f29...cb-221082.html
Asiménio Árma
08-07-2022, 04:37 PM
2021 20' Bambi
San Antonio
Where did you get the solar panel assembly to cover the back kitchen window?
