12-22-2014, 12:47 PM
2022 20' Basecamp
Missoula
, Montana
Blue Ox...Clamp on or bolt on?
I've pretty much decided to go with a Blue Ox hitch for our 19' Flying Cloud. Does anyone know for sure if I can use the clamp on or would I have to go with the bolt on model?
Thanks...
12-22-2014, 01:09 PM
Princeton
, New Jersey
You can clamp the chain brackets to the trailer frame.
I watched this video and can not find anything in the explanation or visual evaluation that would in any way indicate there is a sway control. I can generally evaluate mechanical thing but this one claim is beyond me. The only claim I would agree with is the statement that the hitch is quite. unless the chain brackets have a "hand function" to them the drivers side will be a knuckle buster against the bottom of the propane bottles.
SwayPro By Blue Ox
If anyone can explain the sway control function please post
2004 Excursion 4x4
12-22-2014, 01:23 PM
Princeton
, New Jersey
Let me ask a question. Are the trunnion cups angled in towards the bottom. If that it would cause a additional force to be created on the inner bar during a turn or sway. Not sure I would like to rely on a SPRING as a damping function.
2004 Excursion 4x4
12-22-2014, 01:50 PM
Biloxi
, Mississippi
Thanks...
To actually answer your question the clamp on model is what is suggested by Blue Ox for Airstream frames. I contacted BlueOx prior to buying my BlueOx SwayPro and ask them. Afraid this thread will soon take off in many different unrelated directions like all WD threads tend to do. Good luck
MICHAEL
12-22-2014, 01:59 PM
Sneedville
, Tennessee
I've never busted a knuckle on my BO. Never had a bit of sway either. What amazes me is people who run down a product without any knowledge of how it works. Call BO and they will explain it to you.
12-22-2014, 03:23 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
SwayPro By Blue Ox
http://www.blueox.com/show-4-video.aspx
Can't explain it, but I would like to see one in person and tryout it out.
These videos of the SwayPro by Blue Ox are pretty good, especially the second one from the top, which talks about how leverage returns the trailer to center. It's not dependent on friction to stop sway. Interesting!
I think the any old trunnion type WD would have some of this same leverage effect, leverage returning the trailer to center, if the head is tilted slightly downward like it's supposed to be.
Alan
12-22-2014, 03:35 PM
Sneedville
, Tennessee
Come to Canopener, there will be at least 2 there.
12-22-2014, 03:40 PM
Biloxi
, Mississippi
I will be happy to have anyone take a look mine at Canopener. Spot 008.
MICHAEL
12-22-2014, 04:38 PM
2000 25' Safari
Davidson County
Mrpez and AWCHEIF
I appreciate the invite to take a look. I will not be at Canopener, so maybe another time.
Thanks!
Alan
12-22-2014, 04:39 PM
Sneedville
, Tennessee
I'm right across from you in 19.
12-22-2014, 06:06 PM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Amen! This is my second BO and I have had no issues with 8K plus miles pulling 2- 25' AS's. The new one this year is better with no adjusting needed at the head, but I had no issues with earlier model either. That being said, I am sure someone will pipe in about why "they" think their hitch is better.
12-22-2014, 06:17 PM
Sneedville
, Tennessee
Let's hope not, for once I'd like to see a thread about hitches stay on topic. Plenty of other places to discuss those other ones....wink wink.
12-22-2014, 06:18 PM
Sneedville
, Tennessee
Originally Posted by A W Warn
Mrpez and AWCHEIF
Thanks!
If you have any questions or would like some pictures, let me know.
12-23-2014, 11:20 AM
2013 30' Classic
Greenwood
, Mississippi
Doesn't it work on exactly the same principle as the Equal-i-zer 4-point sway control hitch?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-23-2014, 12:14 PM
2000 25' Safari
Davidson County
No. If you read their advertisements or watch their videos you will see.
I have no experience with either one.
The advertisements say Equalizer uses friction and the BO uses leverage.
Alan
12-23-2014, 12:30 PM
Sneedville
, Tennessee
The BO is nothing like the Equali I Zer hitch.
12-23-2014, 12:52 PM
2013 30' Classic
Greenwood
, Mississippi
Leverage for anti-sway? I don't get it, but it's moot. I'm not shopping for a hitch- just curious, but not curious enough to do a bunch of research on it. I'll take your word for it.
TAC #MS-10
Airforums #70955
12-23-2014, 02:10 PM
Sneedville
, Tennessee
It works. That's all I care about.
12-24-2014, 07:22 AM
Biloxi
, Mississippi
Don't be silly. You know that is not good enough for this bunch of kitchen table engineers.
MICHAEL
12-24-2014, 07:43 AM
K.C.
, Missouri
To the OP, I think the bolt on style brackets are more intended for trailers like V-nose where the body of the trailer extends forward to the point it covers up the front a-frame extension of the trailer. In those examples you don't have access to place the saddle type brackets over the a-frame.
As for whether this hitch works for sway control, I use it on my SOB trailer, which is a typical box, tandem axle, leaf spring setup with flipped axles for high ground clearance ( in other words, probably as "bad" as you can get ). I towed the trailer 600 miles home just "on the ball" and felt a minor amount of sway at times in some heavy crosswinds. Since then I have towed it with the blue ox approx 30K miles, and there is no perceived sway at all under any condition I have towed in. Occasionally at speeds that maybe I should not admit to, but mostly I tow a little under 60 mph.
