09-02-2016, 12:19 PM
san jose
Battery need to be on USE to have solar charge them?
I know this may be a wiring issue, but is it typical to have to leave batteries on USE in order for the Solar to charge?
If I STORE, no charge.
Thanks.
09-02-2016, 12:22 PM
2012 25' FB International
Trent Woods
, North Carolina
No, not usual.
Larry
09-02-2016, 12:35 PM
Sneedville
, Tennessee
Normally a solar charging system is wired directly to the batteries bypassing the Use/Store switch and all the other internal electrical systems of the trailer.
09-02-2016, 12:42 PM
I'm In
, Kentucky
Mine charges in store position. There is a monitoring panel above the stove so wiring does come into the AS from the panel. Mine was factory installed.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
09-02-2016, 12:47 PM
Sneedville
, Tennessee
I don't think even the factory installed solar goes through that switch. I'd have to look at the wiring schematic.
09-03-2016, 04:55 AM
san jose
Thanks all. Strange wiring dealer did then.
Came back to storage after a week to find batteries 36% charged when switched to Store...and that's when I noticed the solar controller lcd is off when in STORE.
09-03-2016, 08:04 AM
I'm In
, Kentucky
No, I don't think anything from the solar panel goes through the Use/Store switch. I think the monitor wiring goes directly to the panel on the wall. I don't have the AS with me but I was thinking there is a separate set of battery lugs for the panel, not sure. I know the monitoring panel and the solar both work when in Store position. Keeps my batteries nicely topped off when I'm not using them.
-Rich
Rich & Yvonne
09-03-2016, 01:02 PM
2016 25' Flying Cloud
Waynesboro
, Virginia
We have factory-installed solar and were told by dealer (Colonial Airstream, Lakewood, NJ) to leave the switch on the "USE" setting. Also told to leave the trailer outside so the batteries can slowly/constantly trickle charge. Always have had 100% power when taking trailer out of storage location.
09-03-2016, 01:42 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Our dealer-installed Zamp solar system (30 amps, one 150 watt panel), like others, works with that switch in the "STORE" position. For our trailer, there is a second set of wires that go directly to the battery terminals. I assume those connect to the solar panel & controller. Pretty sure we're depending on the factory-installed pre-wire for solar.
Of course, your dealer may have done it differently, or maybe Airstream changed things. Our unit is a 2014 model year.
09-05-2016, 08:36 AM
san jose
Was worried about leaving in USE, but batteries stay charged and any minimal power usage by a few things do not offset the charge rate.
Thanks all for the replies; it definitely seems it would be best to go straight to the batteries, but interesting Colonial AS wired to USE (they seem like a top notch dealer).
09-05-2016, 08:53 AM
Trent Woods
, North Carolina
Are you sure Colonial did that? This is the first example I have heard of a dealer wiring solar through the USE switch and I just cannot believe that Colonial would do that.
Larry
09-05-2016, 09:10 AM
Sneedville
, Tennessee
I'm with Larry, there would be no advantage to wiring the solar through that switch.
09-05-2016, 11:20 AM
I'm In
, Kentucky
It's easy to tell if you have the monitor. Whether or not mine is in Use or Store, the readings on the monitor are the same. Whenever I go to check on the trailer the available battery shows 95-100%, depending on the sun.
Put the switch in Store and watch the monitor. See any difference in the readings?
-Rich
Rich & Yvonne
09-06-2016, 08:50 AM
Waynesboro
, Virginia
Don't think Colonial Airstream did any rewiring of the factory-installed solar (don't want to mislead). Actually not sure it makes any difference whether the setting is "USE" or "STORE" with the factory solar option, especially if the trailer is outside and exposed to the sun. The batteries we have require no maintenance and apparently do better with constant "trickle-charging".
09-06-2016, 09:18 AM
2016 28' Pendleton
Scottsdale
Hi from AZ. . . my dealer installed solar system charges either way. . . FYI. . . regards, Craig
WBCCI 2851,4CU
09-06-2016, 09:38 AM
Green Cove Springs
I believe Airstream made some improvements to the solar pre-wire for the 2017 model year, so it is possible they changed this as well. Maybe call Airstream Customer Service and ask them?
