Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 12-14-2018, 12:25 PM   #1
1982 31' Limited
Cranfills Gap , Texas
Water heater replacement for 1982 Airstream Limited
Only lukewarm water, so replaced the gas control valve and the pressure release valve, gas comes on for 15 minutes with a healthy flame.
Then turning water on after 15 minutes only gives a brief 2 cups of hot water, the rest of the water is then lukewarm.
Any suggestions, maybe sediment in the tank?
If a new heater is required what is the brand and where to buy?
Rocket1 is offline   Reply With Quote
Old 12-14-2018, 12:44 PM   #2
1978 31' Excella 500
Barrie , Ontario
I'm wondering if anyone has replaced the furnace in a 1978 31' AS with a portable propane-fueled heater or even a small gas fireplace?
Bev1940 is offline   Reply With Quote
Old 12-14-2018, 01:35 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I replaced my 88 model Atwood 6 gallon with a new Atwood 6 gallon bought from one of the online rv stores. I put in a gas-electric combination unit. I would not do that again. I just use the gas and the combo was just slightly larger than the old unit causing some minor problems in installation ease.
Have not replaced a furnace yet but when I do I will get another furnace installed. I like it being installed where it is and out of the way. Plus it works well with the ducted outlets to the bath and bed areas and it protects the plumbing from freezing when cold weather camping. So I would not like your choice of alternatives
1982 Airstream Limited 34' eBay Watch Airstreams on eBay 0 08-02-2010 07:30 AM
1982 Airstream Limited 34' eBay Watch Airstreams on eBay 0 07-25-2010 09:50 PM
Classic 1982 34ft AIRSTREAM LIMITED Travel Trailer RV eBay Watch Airstreams on eBay 0 11-09-2009 11:40 PM
Classic 1982 34ft AIRSTREAM LIMITED Travel Trailer RV eBay Watch Airstreams on eBay 0 10-16-2009 09:20 PM
Classic 1982 34ft AIRSTREAM LIMITED Travel Trailer RV eBay Watch Airstreams on eBay 0 09-26-2009 05:30 PM
