Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 06-28-2017, 02:55 PM   #21
Calgary , Alberta
Originally Posted by mimiandrews View Post
It looks like someone has used a water line compression fitting on a gas line. The line in the top picture looks more like conduit to me.
I'd suggest that you tear out all the old gas lines and re-plumb with the correct grade of copper lines, double flared fittings, etc. Whatever the safety code requires where you live.
You only get one life.
*SIGH* I was really hoping to avoid that, but your argument is compelling. May have go buy a new range just so that I can connect it.
TheLostBoy is offline   Reply With Quote
Old 06-28-2017, 02:56 PM   #22
Calgary , Alberta
Originally Posted by cwf View Post
We may be truly Lost Boy... =)
Do you have a few pictures of your trailer?
Not at the moment. I won't be able to get out there for a few days (after Tuesday at least), but I'll see what I can post. Getting an ID on this thing would be great.
Old 06-28-2017, 02:57 PM   #23
Calgary , Alberta
Originally Posted by Foiled Again View Post
Please post pictures of your trailer, especially the endcaps. There are a lot of restorers who can ID vintage kin like Travelux, Avion, Silver Streak, etc.
Paula
Sorry, my wife and I are VERY new to camping with a trailer. By endcaps, you mean ends of the trailer, right?
Old 06-28-2017, 03:00 PM   #24
Calgary , Alberta
Originally Posted by markdoane View Post
Solder is not appropriate for gas lines because it can melt out in a fire.
Your best option is to rip it out and replace with copper.
If that is not possible I would braze it, provided it's in an accessible location and it would not be close to a regulator or valve.
Forgive my ignorance, but I thought brazing was soldering (soldering a fitting to pipe end like so: http://www.harrisproductsgroup.com/e...nd-tubing.aspx) in a sense.
Old 06-28-2017, 03:03 PM   #25
Sag Harbor , New York
Brazing uses a much higher temp than soldering, and the resulting joint is very strong and not subject to the same melting as a soldered joint. [end of my knowledge on this!]
I think of brazing as "like welding for non-ferrous metals" +/-."
FWIW
Old 06-28-2017, 03:05 PM   #26
Calgary , Alberta
FWIW
Ok, thanks. I'll have to research more on that, or get a professional to perform the task.
Old 06-28-2017, 06:43 PM   #27
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
And then there's silver soldering, that is the high test way to join copper.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 06-28-2017, 07:28 PM   #28
1988 32' Excella
West Palm Beach , Florida
Google Swagelok fittings and pipe is probably high pressure stainless steel.
2dogtraveler is offline   Reply With Quote
Old 06-28-2017, 08:15 PM   #29
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
The cooper line is just regular tube. Cut the feral off, ream it and flair it.
On the aluminum line your going to have to show us the end where it attaches to the appliance. I'm thinking there's an adapter there that you could change. The tube/pipe is metric. But if there's a threaded adapter you could adapt it.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
Bigventure is offline   Reply With Quote
Old 06-28-2017, 10:18 PM   #30
Wise Elder
Jammer's Avatar
2010 30' Classic
It is common to silver solder gas lines, though not in trailers. Less fitting cost than flare, smaller fitting, same labor.
Old 06-28-2017, 10:20 PM   #31
Wise Elder
Jammer's Avatar
2010 30' Classic
The connections to the appliances themselves are almost always NPT with an adapter to flare or whatever.
Old 07-14-2017, 09:51 AM   #32
Calgary , Alberta
Gave up...
*FINAL UPDATE*
I've been trying to find a fitting for this pipe for months and couldn't find any supplier who had anything that would fit this pipe. Most of the ones I talked to said it would be easier to re-run the line with new and STANDARD fittings, which is exactly what I did. Took my only two evenings (was pretty simple actually) and a couple trips to a plumbing shop and as of yesterday evening, my propane fridge is up and running!
I REALLY wish that I'd had just done this from the start as it was much faster and simpler. Thanks to everyone for your great tips and feedback.
TLB
Old 07-14-2017, 10:37 AM   #33
1972 25' Tradewind
Calgary , Alberta
That task is done. Now let's see some pictures of this trailer, you've sparked interested in us all to see what it is.
Was it a barn type find in and around the Calgary area?
Monza is offline   Reply With Quote
Old 07-14-2017, 10:38 AM   #34
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Excellent!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-14-2017, 10:45 AM   #35
Calgary , Alberta
I don't know what "barn type" means, sorry, but I'm very new to RV'ing. I did take a photo last night: http://imgur.com/a/dHdQB
Yep, we are in Calgary.
Old 07-14-2017, 11:26 AM   #36
1972 25' Tradewind
Calgary , Alberta
Cool. My guess, it's a Shasta, but I don't really know, I'm sure others here can tell you exactly what you have.
Have fun fixing her up!
A ' barn find' is a term regarding finding a old car, trailer that has been lost or forgotten about in a barn.
You could also do a google search of old trailer ID and get lots of images and reference you trailer to those.
Old 07-14-2017, 03:46 PM   #37
Calgary , Alberta
No, not a barn. Bought it off another fellow who outgrew it.
We're actually having a bit of fun restoring it (though, quite a bit of frustration with some stuff).
So, What have 'you' found while restoring?? balrgn Off Topic Forum 148 04-26-2010 09:51 AM
How to flare tubing... Buttercup LP Gas, Piping, Tanks & Regulators 15 07-27-2005 07:51 PM
Copper LP gas tubing jperryfly LP Gas, Piping, Tanks & Regulators 22 06-10-2004 03:10 PM
E-PEX tubing Pahaska Fresh Water Systems 3 03-03-2003 12:03 PM
