08-17-2008, 02:58 PM
1967 26' Overlander
Phoenix
Propane to Natural Gas Conversion HELP
I am setting up my 1967 Airstream as a semi-permanent guest house in my backyard, and have a few hurdles I need some advice on.
I would like to hook the RV up to the natural gas line on my house, but don't know what needs to be modified to make this work with the propane system of the RV. Ideally, I would love to replace or add one regulator to the entire system but can of course make adjustments to both the gas water heater and stove separately if need be.
Any advice would be greatly appreciated!
Thank you.
Christoph
08-17-2008, 03:19 PM
1967 26' Overlander
Huntsville
, Alabama
It would be easy if it was not an RV
Originally Posted by kaiserbox@gm
... I would like to hook the RV up to the natural gas line on my house, but don't know what needs to be modified to make this work with the propane system of the RV. Ideally, I would love to replace or ...
Welcome to the forum.
The Gas Company's regulator will do all the regulating necessary. You do not need another regulator.
Your gas appliances will need different gas jets. Your gas company should be able to advise you on the correct replacement jet sizes. They will, however, probably not be able to help you locate the exact part you need.
RV appliances were designed to operate only on propane. The appliances' respective manufacturers most likely put little thought into stocking gas jets which work with natural gas. You might have trouble locating what you need.
Or, you might find that the vendor used industry-standard jets.
Are you handy enough to change out the jets in everything should you be able to find the correct replacements?
Tom
08-17-2008, 03:59 PM
1984 31' Airstream310
Ajo
Sounds like a p.i.t.b, pay the gas guys to tell you if it's possible. Why not have a propane
tank installed?
08-17-2008, 06:45 PM
1978 31' Excella 500
Venice
Here's the chart.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
08-17-2008, 07:17 PM
1999 27' Safari
Kent
, Ohio
It is simple but costly. Every unit that you are going to run on natural gas you have to switch the control from a propane or LPG control to a nat gas control. I would think if you wanted hot water use a Hot water line off your house and plum it into your trailer hot water line.Your frige runs off electric and your range that wont use much at all. Or just cook on the grill outside or over a fire. Get the whole efect that way
08-17-2008, 07:49 PM
2002 25' Safari
Dewey
Welcome to the forums from another Phoenix Airstream owner. We have quite a few owners here in the valley. Great to have one more.
I am sure if Southwest Gas (gas company in Phoenix) sees a line to the trailer, they will cap it and red tag your setup. I had an experience with them in my last house (no gas in my present home) where they disconnected me because the room the water heater was in did not have proper ventilation. The same room the water heater sat in since the home was built in the 70's. I doubt that your 40+ year old trailer will meet all the code requirement for residential Phoenix.
Richard
08-17-2008, 11:17 PM
1967 26' Overlander
Phoenix
Thank you.
I appreciate your insights, all very helpful. I think I will go with your suggestion to run the hot water from my house and simply use the propane tanks for the stove. This will let me take the rv out without having to switch stuff back...
Any idea how long two normal size bbq tanks can be used? How many (average) meals before the tanks are depleted?
Thanks again!
08-17-2008, 11:22 PM
1967 26' Overlander
Phoenix
One more question.
Maybe this should be a separate thread, but I will be connecting the rv to sewer - should the abs pipe to the sewer have a p-trap prior to coming out of the ground (to the trailer) or does the rv toilet have built in way of stopping sewer gases from entering the interior?
Thank you.
08-18-2008, 12:21 AM
2002 25' Safari
Dewey
You would keep the black tank valve closed untill the tank is near full then dump and close the valve again. It is the only way to get the solids out of the tank. Keeping the valve open will create the "black hills" effect in the tank.
Your gray water fould just flow since you have no gray tank. You would need to make sure that the P-traps in the sinks and shower always have water in them.
Richard
08-19-2008, 05:40 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
If you want to set it up permanately,you must call a plumber to drill out the orfices,the burner valves will work just fine.Some stoves are adjustable and don`t need different orfices.They will have to pull permit,pressure test system ,have an inspection.Also sewer tie in needs permit and inspection. NO TRAP ON SEWER LINE.
Azflycaster-if they taged you it was probably for lack of combustion air.Hope this helps.Dave
08-21-2008, 02:35 PM
1999 27' Safari
Kent
, Ohio
its always nice if you putting in a new septic tank just have them punch a whole and give you a dump station to hook to
