Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 12-12-2003, 06:30 PM   #1
Navigator
Profile:
Propane Tanks: 30# or 40#?
My rehab trailer came without propane tanks, but it does have the hold down bracket.
My problem is that I do not know what size tanks the support assembly was designed for.
Could someone please tell me the # capacity of your tank,
and
the distance from the tongue to the apex of the inverted U in your hold down bracket?
Also, the length and width of the base bracket that holds the weight of the tanks on the bottom?.
Thanks in advance,
Dick
Navigator is offline   Reply With Quote
Old 12-12-2003, 07:35 PM   #2
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
A better Solution
It would be easier if you would measure the upright threaded rod on your rig and then someone here can tell you what will fit that dimension.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 12-12-2003, 07:58 PM   #3
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
OR... better yet, check AirstreamDreams.com's website. They have dimensions of the tanks there.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 12-12-2003, 10:59 PM   #4
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Dick,
If you have the holdown bracket that is a long metal rod with a couple big aluminum wing nuts on top, check it out down low, there should be 2-4 holes drilled in it, this to allow for different sized tanks, you remove the bolt from the back of the tank rack and move the rod up an down. I will try to get a picture tomorrow for you. Mine is set up for 30#ers at the moment. However I have a couple of 100#ers setting on the ground hooked up at the moment to keep it warm so I can work on the interior I think it will accept 20#-30# steel and 30# aluminum. I also have seen pictures of 40# but I don't know if they were using the stock bracket or not.
Aaron
Old 12-13-2003, 09:01 AM   #5
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Dick!
I have the 40 pound Worthington Aluminum tanks on my '64 Overlander that were purchased from Airstream Dreams. I am using the standard Airstream bracket from the 1970s. The only modification necessary was the addition of a 6" longer threaded rod (purchased from my local Ace Hardware store). The 40 pound Worthingtons replaced my 30 pound steel tanks that were in desperate need of replacement. I am VERY pleased with the added capacity of the 40 pound tanks as I rarely need to refill during an entire season of RVing. The tanks can be seen in the photo below:
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 12-13-2003, 10:41 AM   #6
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
BTW we have 20 LB'rs because proportionately the others seem too big for our little trailer. We go out for 20-25 days without a refill in the May-Oct months....almost all summer for us.
Shari
Old 12-14-2003, 11:06 AM   #7
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
What 40 lb Tanks look like
Navigator,
This picture will allow you to judge whether you can accommodate 40 lb tanks. These are Worthington aluminum tanks. I sent you a private message on the dimensions.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 12-14-2003, 11:23 AM   #8
Sue&Von
Profile:
Davydd thanks for the pic. But why just PM the dimensions of the tanks? They could be useful to some other member some day don't you imagine. How about adding them here.
thanks
$&V
Sue&Von is offline   Reply With Quote
Old 12-14-2003, 11:40 AM   #9
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
40 lb Tank Dimensions
Sue&Von,
I replied to Navigator in a private message he sent but could not attach the picture so came back to the forum and attached it here since it seems referencing my photo library at this time would be futile. Here are the dimensions.
The overall height of the tanks are 32" from bottom of base ring to the top of the collar. The hold down bracket that grabs at the opening in the collar measures 28" at the thread from the bottom of the base to the bottom of the hold down. The top of the Tee handle is at 33". The picture can give you a visual reference.
Davydd
Old 12-14-2003, 01:20 PM   #10
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
If you check the AirstreamDreams website linked in my earlier post, the dimensions of all three sizes of Worthington Aluminum Tanks are there including diagrams and cost. Here they are again...
20 lb
30 lb
40 lb
Shari
Old 12-14-2003, 03:12 PM   #11
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Drat!
I was 0.06" short on the dimension of my 40 lb tanks. Probably metal fatigue after 32 years. Now that I know what they cost I better invest in a lockdown.
Davydd
Old 12-14-2003, 04:08 PM   #12
Navigator
Profile:
Greetings Good people,
Wahoonc,
You are right, I just need to get a longer rod.
Overlander64,
You convinced me to go w/ 40 lbs.
Insideout,
Thanks for the lead, thats where I am going to order my Al tanks.
Davydd,
The picture says it all; Thanks.
Dick
