Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 08-27-2014, 02:31 PM   #1
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Propane tank level checker
I saw an ad for Truma in a mag recently and bought one. They are a well established German RV company and this device is a little handheld sonic detector. It seems to work well on a clean tank but gives false negatives on a dirty tank. So it is fine for my AS tanks, not so good for a bbq grill tank stored outside.
You may ask why bother...I like to start trips with two full tanks but I want to know whether I really I really need propane in the in service tank without having to wrestle it down and weigh it. Perfect device for the job!
Larry
lsbrodsky is offline   Reply With Quote
Old 08-27-2014, 03:06 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
There's an even cheaper tester: hot water. Pour it down the side of your propane cylinder, then feel the wet side of the cylinder. Where the cylinder switches from feeling hot to feeling cool, that's where the propane level is. Propane is very cold in its liquid state, and it will suck the heat right out of the water you poured on the cylinder.
Old 08-27-2014, 03:47 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto, been doing it that way for years. Sometimes you just got to pass on the tech.
MICHAEL
Old 08-27-2014, 04:00 PM   #4
lsbrodsky's Avatar
Not me...tech is good. Why would I want water all over the tank and base when they are normally protected from the weather?
Larry
Old 08-27-2014, 04:16 PM   #5
r carl's Avatar
Lin , Ne
I tried that one time, it must not work on aluminum tanks.
Old 08-27-2014, 04:39 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use the gadget and like like it, simple to know levels as we travel. No surprises. I think of it like the black tank, fresh and grey water and gasoline gauges, better than a dip stick.
Doug and Cheryl
Old 08-30-2014, 04:02 PM   #7
2004 16' International CCD
Chicagoland , Illinois
Hmm. I like the water trick, but I like tech too. Thanks for sharing these tricks.
Airrogant is offline   Reply With Quote
Old 08-30-2014, 04:10 PM   #8
1999 28' Excella
New Orleans , Louisiana
How much hot water?
badkat is offline   Reply With Quote
Old 08-30-2014, 04:15 PM   #9
dougandlori's Avatar
2004 28' Classic
Fresno , California
I just use a large glass of hot water and it works every time.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 08-30-2014, 04:23 PM   #10
IanPoulin's Avatar
2021 25' International
Full timer , Virginia
At one hundred dollars for the Truma, I think I'll forgo the tech and use the hot water method
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2024 Airstream Globetrotter 30RB
2022 Ford F350 Lariat Diesel
WBCCI 4CU 8118
IanPoulin is offline   Reply With Quote
Old 08-30-2014, 05:39 PM   #11
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I just bought one. It was $69. A bit spend, but isn't everything these days?
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-30-2014, 07:44 PM   #12
2005 19' Safari
GLENDALE , AZ
I weigh the propane tanks using a cheap scale that we got at WalMart near the luggage and travel stuff:
http://www.walmart.com/ip/17472591
The "tare weight" of an empty propane tank is stamped on the metal handle. To determine how much propane is left in a tank, just weigh it and subtract the tare weight. (I weigh the tanks right after I fill them, and write the weight on the top of each one, in pencil; that way I know how much they weighed when full.)
The scale isn't terribly accurate (+/- a pound or two), but this isn't rocket science. The measurements are close enough to determine whether a tank should be refilled. Besides the scale only costs about $6-7.
Old 08-30-2014, 09:06 PM   #13
AWCHIEF's Avatar
Images: 33
You can also just pick it up and give it a shake. Pretty easy to judge how much liquid is in the tank.
MICHAEL
Old 08-30-2014, 10:41 PM   #14
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Yea but once you pay to heat sixty thousand glasses of water you could have bought the device.
Old 08-30-2014, 11:59 PM   #15
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Larry
Possible that you could tell me how this device was listed in the Magazine, or even the Product name from the box it came in?
Thanks, Derek
Old 08-31-2014, 04:06 AM   #16
lsbrodsky's Avatar
It is called the Truma Levelcheck and you can find it at truma.com
Larry
Old 08-31-2014, 05:59 AM   #17
1997 25' Excella
Waterville , Minnesota
I fill propane tanks here at the shop and seen various kinds of these, however after time or a slight "dropping" of tanks they seem to read inaccurate. I can only agree with Phoenix, the tare weight is stamped on the tank (TW) and depending on your tank size, being a 30# or 40# add the (TW) to the tank size and you will have the full limit of your tank. You should not have to write anything down, unless the filler is not giving you your moneys worth. A bathroom scale will work for this just fine. A 30# tank when full should be about 54 lbs. Aluminum of course is lighter and the TW would show this.
Bait guy is offline   Reply With Quote
Old 08-31-2014, 06:39 AM   #18
1981 31' Excella II
New Market , Alabama
You can get a double bung tank with a float gage in it.
Perry
Old 08-31-2014, 09:11 AM   #19
2020 Classic 33
Box Elder , South Dakota
I've got the MOSCAP tank ultrasonic checker and it works well. http://www.amazon.com/GasCheck-Propa.../dp/B00EUG1DCE
Also have heard that an IR thermometer will work. Just need to have some propane being used. When gas is flowing the propane will get colder.
And the most accurate way as previously mentioned is weight. 50# fish scale will do fine since most tanks empty are about 23# or so, at least the ones on late model AS.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 08-31-2014, 09:29 AM   #20
lsbrodsky's Avatar
Yes weighing is the most accurate, but my objective was to avoid having to disconnect and lift the tank off of the A-frame. The ultrasonic sensor is a more elegant and less physical solution for me.
Larry
Polarity checker. ROBERTSUNRUS Lights - Interior & Exterior 5 10-05-2012 04:54 PM
ieSpell - a spell checker for internet explorer toastie Off Topic Forum 3 12-05-2010 08:30 AM
Spell checker... (ieSpell) Andy R Forum Admin, News and Member Account Info 11 11-02-2007 07:11 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Spell Checker thenewkid64 Forum Admin, News and Member Account Info 25 04-29-2004 10:21 AM
