10-06-2005, 05:46 PM
1977 31' Excella 500
Berkeley Springs
, West Virginia
LP Bottle Size
Hi Everyone,
I recently bought a '77 Excella that came without the LP bottles. I believe this trailer originally had the 30lb units.
Does anyone know if the 40lb bottles will fit OK?
I got the dimensions from Worthington's website and made a cardboard cutout of a 40lb bottle (30 is the same size, just shorter) that I could put up to see. It looks to me like it'd clear the arc made by the front window swinging open by a few inches. Is that enough? Is a lot extra required to clear the regulator? Has anyone else done this? Any guidance would be appreciated.
Thanks!
10-06-2005, 05:52 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Jim,
I am pretty sure the 40# tanks should fit, at worst you may have to extend the rod that holds the tanks down. Mine is long enough for the 40's. The regulator on my unit hangs down kind of between the tanks to there is no problem with clearance. nI have also considered moving the tank rack further out closer to the jack which would help clear the front window cover.
Aaron
WBCCI #XXXX AIR #2495
10-06-2005, 05:55 PM
1999 34' Limited
1962 19' Globetrotter
Northern
tanks
You can change the position of your regulator with longer hoses. You might also want to think about getting the kind you can take off the bottle without tools. They tighten by hand. You also may have to install a longer hold down rod.
10-06-2005, 06:57 PM
Berkeley Springs
, West Virginia
Thank you for your replies. I'm going to try and find a real 40lber to set on there. I think it will work out fine.
Wahoonc, are those the 40lb bottles on the little picture by your name? They look taller than standard. Looks like they fit fine.
Bradjun1, the polish finish on the trailer in your little picture by your name looks absolutely beautiful. I hope to make mine look like that some day.
Thanks again!
10-06-2005, 07:07 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Jim,
That is a stock avatar...looks alot better than my trailer at the moment I have 30#ers on mine and during the winter I put a couple of 100# tanks out there
Aaron
10-06-2005, 07:24 PM
1999 34' Limited
Northern
avatar
That is not a stock avatar. That's our new poilsh job!! Just finished it last month. There ae more pictures posted in our gallery. It took about 100 hrs to complete. Brad
10-06-2005, 07:49 PM
Airstream - Other
Bosque Farms
, New Mexico
The 40s might just fit. The aluminum bottles that probably were original with your unit were likely 30s, but the aluminum bottles that I've dealt with also have taller collars than the steel bottles; hence, the hold-down rod on these Airstreams was longer than rods with steel-bottle rigs. (Not knowing that, I stupidly shortened the rod on ours years ago. Another one of those for the really-dumb-things-that-Lynn-has-done pile.)
Lynn
ACI Big Red Number 21043
10-06-2005, 10:55 PM
1999 34' Limited
Northern
I'm sure the originals were 30# but the 40# should fit with no major work. I have to say I never ran low even with the twin 30's. Good Luck Brad
10-07-2005, 06:20 AM
1976 31' Sovereign
Chandler
, Oklahoma
My avatar shows the larger bottles on the front of a 24ft 1978 Argosy. No trouble with them at all.
11-20-2005, 06:27 PM
1986 25' Sovereign
Southern Middle
, Tennessee
Hi Everyone,
Thanks!
Jim,
My '77 Excella has 40 lb. Aluminum tanks.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
11-20-2005, 07:21 PM
Putnam
, Connecticut
Originally Posted by wahoonc
Jim,
Aaron
That's quite the pair you have Aaron.
11-20-2005, 08:08 PM
Retired.
, At Large
I recently went to look at an Airstream for sale with 40# tanks, they cleared the rock guard with no problem.
