Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1994 - 1996 Excella
Old 05-11-2018, 06:03 PM   #1
doonanner's Avatar
Remlap , Alabama
What the heck did I do wrong?
So I attached a water hose to this spigot however water started to leak ( badly) underneath the Airstream! Am I missing something? Please help me out as you can tell I am a rookie!Click image for larger version
doonanner is offline   Reply With Quote
Old 05-11-2018, 06:11 PM   #2
Sag Harbor , New York
Have you read your owner's manual about the plumbing system etc.?
What year and model AS do you have? You could add this info to your ID at the left at some point, in the User Control Panel via the drop down menu in the Quick Links in the blue menu bar above.
What is the status of your AS? Was it winterized for instance, and are your low point drains open perhaps? Did your plumbing freeze up over the winter, and you have broken pipes which are leaking?
If you give us some more background and info, you will get more productive feedback.
Cheers,
Peter
PS -- Your other threads for everyone's info:
http://www.airforums.com/forums/f258...ds-181032.html
http://www.airforums.com/forums/f186...lp-175896.html
I am guessing you did not buy this old Sovereign?
Old 05-11-2018, 06:16 PM   #3
doonanner's Avatar
Remlap , Alabama
She is a 1994 Excella 1000, water was drained prior to winter but that was all.
Old 05-11-2018, 06:18 PM   #4
Please answer as much as possible as requested in Post #2, which has been edited recently.
Peter
Old 05-12-2018, 09:17 AM   #5
1985 31' Excella
st. Paul , mn
This should be a clue " water was drained prior to winter but that was all "
Like mentioned above - read the manual , and look for the water drain valves .
Close , and all should be good .
REMEMBER TO USE THEM AND DRAIN BEFORE NEXT WITNER !
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 05:02 PM
If I Did a 'Blow Out' Of the Water Lines and No Water Came Out Did I do it Wrong? mrpettit Winterizing, Storage, Carports & Covers 15 12-03-2014 09:51 AM
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 07:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
What did I do wrong Roadtoaster Electrical - Systems, Generators, Batteries & Solar 1 10-16-2006 03:32 PM
