Old 06-13-2004, 03:54 PM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 31
Send a message via ICQ to gklott Send a message via AIM to gklott Send a message via MSN to gklott Send a message via Yahoo to gklott
Hiding Wiring in 30' Walls - 2004 Classic
Want to mount a Link 10 DC metering system in the street side of the upper cabinet in the front of our 2004 30'. The shunt will be under the sofa with the batteries. So I need to get wires from the upper cabinet to the sofa below (small multi-conductor I believe).
Has anyone had luck running wiring in the walls?
Any suggestions on how to minimize removing the wall covering?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic dinette
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 06-13-2004, 03:58 PM   #2
gklott's Avatar
2004 30' Classic
Images: 31
Make that a Link 20 for dual batteries.
73/gus
Hensley/Prodigy
Old 06-14-2004, 10:03 AM   #3
73/gus
One could run it straight up the front wall, relying on the curtains to hide it. But I wouldn't.
Fishing wire through the walls is virtually impossible due to stringers, other wiring, fiberglass batts, and whatever else is in there.
I'd just go ahead and open up one side of a panel. It is not at all hard to drill out the rivets and replace them with new pop rivets. And you don't need the panel off, just loose enough to sneak a wire up.
Mark
2004 classic
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
