08-10-2015, 04:11 PM
2014 Interstate Ext. Coach
Monroe
No current from Interstate factory solar
My solar panel rarely produces any current. Most days, nothing. Every time I am in the van, I check the output. Literally 99% of the time, no current.
I have a 2014.5 Interstate van. It includes a factory solar system, with Ameresco 50W solar panel 50J and Sunexplorer PVCM25D/PVDM4-LC charge controller and display.
From time to time, every now and then, I'll see some current on the display. I've used the van 50 days in the past 6 months, and I think I've seen it produce current twice.
In bright sunlight, with sun directly overhead, no current.
With battery above or below 12.75V, no current.
With battery quite low, no current.
And then, one day, it will be producing. Then back to nothing the next 50 times (days) I look at it.
Since it works from time to time, it's not a fuse. For the past 12 months, the total output of the 50W panel, parked outside all day, is 120 AH. Total.
Does anyone think there is a way I might fix this myself? I am so tired of taking this Interstate back to the dealer.
08-10-2015, 04:45 PM
2011 Interstate Coach
Overland Park
, Kansas
Are you plugged into shore power? It sounds like your solar controller has gone Tango Uniform. Call Robert Kendall at Atkinson Electronics 800-261-3602 and describe what you see. He is very helpful and after determining that mine was bad, sent me a new one free, no questions asked. Just wanted me to return the old one to him for failure analysis. YMMV
BTW it is easy to replace. It resides under the lounge on curbside near the BIM.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
08-10-2015, 04:53 PM
Biloxi
, Mississippi
Warranty time!
MICHAEL
08-10-2015, 04:54 PM
Monroe
P.S. The van spends most of its time NOT plugged in. I have to go out to the storage lot every ten days or so to plug it in for a couple of hours to keep the batteries up, which it what makes the missing solar power so annoying.
08-10-2015, 05:43 PM
KW
, Ontario
Don't waste your time with the horrible electronics AS installed.
Replace the factory charge controller with a Morningstar. I replaced mine with a Prostar 30. What a difference. Bought in on Amazon. You can actually leave the old charge controller connected to the power so that the voltage readout on side will still work. Disconnect the Yellow wire coming into the old charge controller and the Green wire on the ground terminal and then feed them into the new one. Attach the output wires to ground and plus and its up and running. On my unit I moved the old charge controller to the bottom and used the old location for the new Prostar 30. I bought the one with the built in meter only so I could see the charge current, but its not necessary. I also set the setting to flooded even though I have AGMs. Now I actually have the right voltage and the batteries are always charged.
Good luck.
08-10-2015, 05:58 PM
Naples
There are many ways to upgrade your inefficient 50 watt solar charging system. Initially, you have a single stage charge controller (just like the trailers that have a single stage, constant voltage converter) that will NEVER charge your batteries properly, regardless of how many watts of solar you have on your roof. A digital, 3 stage solar charge controller will go a long way toward extending your battery life.
Next. with a small array, you certainly don't want to waste ANY of the voltage coming from that array. The way Airstream routes the charging wires has too much length for the wire gauge used to not show voltage drop, and there are far too many connections between the solar panels, charge controller and batteries to be really effective!
Finally, even 50 watts will, at best, give you a couple of amps (basically a trickle charge) into your batteries. Airstream uses Lifeline AGM batteries from the factory in the solar option. These batteries demand proper voltage and 3-stage charging for maximum longevity, which is 14.2-14.4VDC for the Bulk and Absorption charge and 13.2 VDC for the float charge. BTW, this is NOT THE SAME as using a liquid lead acid battery setting on a Morningstar controller!! That's why the AGM setting is available on the Morningstar controllers.
Any other voltages charging the Lifelines are not optimal, and will noticeably shorten their useful life.
If someone thinks that they have more knowledge or empirical data on better charge set points for use with Lifeline AGM batteries, perhaps they should offer their services to the factory!!
lewster
08-11-2015, 06:28 AM
2020 Atlas
Treasure Island
When Lewster did a solar upgrade for me, it was discovered that my solar controller was not even properly connected. It was obvious that something was wrong, because my house batteries would not charge. Very similar to the issue you seem to be having. My suggestion is to get it looked at by a RV solar specialist
2014 Airstream Interstate
Mostly a "Weekender" but currently on a cross country trip to Yellowstone.
Wherever you go, there you are!
08-11-2015, 06:56 AM
Biloxi
, Mississippi
Lew, what would a ball park low budget figure be for a 200 watt system be installed by you on a 2006 Safari 23? No commitment just a number to start thinking about.
MICHAEL
08-30-2015, 09:51 AM
2015 Interstate Ext. Coach
Chicago
As a result of reading through many of these battery posts, I'm thinking of upgrading the solar controller /charger to a 3 stage. I won't be able to do it myself, so need to figure out 1)what kind specifically (e.g. is MPPT worth considering?); 2) which brand; 3) what type of dealer to look for to do it ... presumably NOT my local Airstream dealer.
Here's one link that I've been reading to get a better handle on the issues.
Solar Charge Controller Basics
Any other inputs Lew? You're obviously very knowledgeable about this topic, and get quite a few endorsements from the other posters.
Thanks for any info you can provide
Mark
08-30-2015, 12:40 PM
Naples
The basic problem is the small size of the 50 watt solar panel. An MPPT controller will not provide any benefit with lower wattage ( 100 watts or less) solar arrays over and above a basic PWM controller with adjustable charging output.
I would look at the lower end solar controllers from Morningstar for a better solution if you intend to keep your solar capacity at 50 watts.
OTOH, if you want to upgrade the solar charging system including enlarging the solar array, that presents a different scenario.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
08-30-2015, 12:47 PM
Chicago
I have the 100w solar, but it seems your advice would be the same
Any idea what kind of dealers / servicers I should look for? (e.g. RV service? Or solar companies?)
THANKS for your response
08-30-2015, 12:53 PM
Naples
Where are you located?
Lew Farber
541-490-6357
lewster
08-30-2015, 02:13 PM
Chicago
Lew Farber
541-490-6357
Chicago My AI dealer is in Joliet, which is just 45-50 miles, but not sure they would be a good solar controller installer
08-30-2015, 03:35 PM
Naples
Give AM Solar a call to see if they have any experienced installers in your area. 1-541-726-1491
Lew Farber
541-490-6357
lewster
08-30-2015, 07:12 PM
Chicago
Lew Farber
541-490-6357
Great. Will do THX!
08-31-2015, 07:46 AM
Chicago
Lew Farber
541-490-6357
Lew, sorry to keep at this topic, but I'm reading the solar controller manual that came with my 2015 AI Grand Tour, and it makes it SOUND like over-charging would not be a problem.
SUNEXPLORER PVCM25D
5 functions:
1) senses when the battery is fully charged and disconnects the PV charge current to avoid over-charging the battery
2) resumes charging the battery when the battery voltage has dropped sufficiently
3) checks the availability of PV charge current, by cycling the relay every 4 minutes
4) compensates for battery temp and adjusts the charge threshold voltages when mounted in battery cases
5) microprocessor reduces the charging rate of fully charged batteries to minimize water addition requirements
...is this a single stage charger? And should I still worry about overcharging in a high sun uncovered storage environment?
Thanks again for any perspective you can provide.
mark
08-31-2015, 08:36 AM
Naples
From their nebulous and purposely vague description, it sounds like it is a fully automatic controller with full temperature compensation. Is this done miraculously(?), as they do not use a remote temp. sensor on the batteries, nor do they state what the voltage charge profiles are.
In any event, they DO state that it is set for liquid cells. That alone would make the unit incompatible with Lifelines.
Unfortunately, Airstream has a long history of ignoring the use of better quality battery charging hardware. Simply look at their single stage battery-burners used in ALL of their trailers and this solar controller...... not to mention their specific exclusion of the temperature sensing probe that Magnum provides with every inverter/charger and their use of the very basic ME-MR remote.
I would still upgrade the solar controller.
Lew Farber
541-490-6357
lewster
08-31-2015, 11:44 AM
Chicago
Lew Farber
541-490-6357
Yeah I guess I agree. Shame about the choices they make. Thanks again
08-31-2015, 01:05 PM
Overland Park
, Kansas
FWIW, the charge controller module is only about a foot away from the batteries. So the temperature compensation should work with the one exception of in the winter time when the interior was being heated and the bottom battery would be closer to outside temperature.
08-31-2015, 07:39 PM
Naples
Proper temperature compensation for battery charging should accurately measure the cell temperatures at the battery and not the ambient air temps. They can vary dramatically........ and with it the charging voltages that the sensor should be controlling. This is why Magnum and Blue Sky require their temp. sensors be secured to a negative battery terminal for accurate measurements.
lewster
