11-17-2016, 10:03 AM
2017 Interstate Grand Tour Ext
San Diego
Air Bags Worth It?
Is air suspension on the new AI a valuable option?
11-17-2016, 11:50 AM
Biloxi
, Mississippi
As much as they want for it I would consider it valuable.
MICHAEL
11-17-2016, 02:48 PM
2011 Interstate Coach
Overland Park
, Kansas
Sort of depends if anyone plans to ride in the rear as on the 8/9 psgr AIs, the rear seating tends to launch riders into low earth orbit.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
11-22-2016, 05:14 PM
Monroe
, North Carolina
I take delivery of my 2017 Grand Tour with VB Air Suspension next week and will report back on them. I wanted them more for leveling and ride quality than I was concerned with people sitting in the back not bouncing around.
11-23-2016, 02:59 PM
Houston
For me yes. I have over 20K miles on my '16 with VB-Air. Improves the ride, but also, I use it regularly to fine tune leveling at campgrounds and have on more than one occasion had to use the AIr suspension to raise the rear when backing into a step incline to avoid dragging. Wouldn't have the van without it after living with it.
11-24-2016, 08:56 AM
2024 Interstate 19
Fulton
, Maryland
Yes for me too. But I don't have VB-Air system. Installed the Dunlop Auxiliary airbag system to rear axle. It also improved the ride a bit, but more important gave me the ability to adjust the height of the rear end for same reasons cited by Mcrider above.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
11-24-2016, 09:21 AM
San Diego
Thanks for your useful response. Does the system provide side-to-side leveling as well as front-to-back?
11-24-2016, 09:35 AM
Houston
The VB does not. Just front-to-back.
11-24-2016, 07:03 PM
2024 Interstate 19
Fulton
, Maryland
Yes - I installed an AirLift compressor with remote control so I can adjust pressure on each side. I can also adjust ride height while moving which the VB-Air system won't do unless you bypass the parking brake interlock.
- - Mike
- - Mike
11-30-2016, 08:20 PM
Monroe
, North Carolina
My 2017 was delivered yesterday. VB Air System is non-responsive. Left message for out-of-state dealer and Airstream. Let the games begin...
12-01-2016, 12:01 PM
Houston
Make sure you have the parking brake set and key on.
12-02-2016, 05:40 PM
Monroe
, North Carolina
Thank you for the tip! I received the same response from my dealer, Airstream and VB Air after reaching out to them. I've been pleased with the response time from everyone. Unfortunately, the break was not the culprit. My dealer agreed with me that oose fuses often cause issues like mine and it becomes necessary to tighten the metal contacts within the fuse box and/or apply dielectric grease to the fuse for proper connection. So far, the system is working great!
12-02-2016, 10:06 PM
2014 Interstate Ext. Coach
Sedona
Curious to know if the vehicle is essentially disabled when the VB Air Suspension is out of action?
12-03-2016, 05:46 AM
Monroe
, North Carolina
The vehicle is not disabled in any way when the VB Air system is not working.
12-03-2016, 01:13 PM
2024 Interstate 19
Fulton
, Maryland
The air bags still have air pressure in then, but without power the pressure can't be adjusted. The only thing that could cause problems is an actual leak in the air bags.
- - Mike
- - Mike
12-03-2016, 08:25 PM
Sedona
- - Mike
Yes, that's why I asked, because I know of one Advanced RV that had to be loaded onto a low loader when one airbag failed. Probably the risk you take with any air suspension.
