Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 10-06-2014, 10:21 AM   #21
2014 25' FB International
Metuchen , New Jersey
Originally Posted by A W Warn View Post
480 lbs is approximately your trailer's tongue weight. I think you need to add a little weight to the front of the trailer so that the tongue weight is about 10% of the trailer gross weight.
If the total sum of tongue weight, hitch weight, and sway control weight does not exceed the rating of your hitch, all is well.
I think you are good to go!
add edit:
I did not see the CAT Scale result since it was posted while I was typing.
Did you have the jack down on the center platform to get that 1,100 lb tongue weight?
Please explain how the vehicles were positioned during each weigh.
From what I remember I unhitched and drove to the platform in front of me & the trailer jack was on the platform behind me, not sure if it was dead center, and the trailer axles were on the third platform.
add edit 2:
unless you pulled on the scale backward the top number is the tow vehicle (front platform) not the trailer
I might have.
That's the way it was explained to me when I picked up the tickets. It does make sense that it is the trailer when you add the tongue 1100# & trailer 6420# = 7520# which is close to the trailers GVWR 7300#.
GenXair is offline   Reply With Quote
Old 10-06-2014, 02:42 PM   #22
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
If you were to remove the two batteries from the battery box to the front bed area, say against the front bed frame how much weight do you expect to come off the tongue weight? My two Interstate Grp 27 weight about 53lbs. I think equivalent AGMs are about 65lbs each. I've weighed my 2008 Classic 25fb and its about 1100 lbs using my Sherline scale. Just wondering if its worth it. Tow vehicle is a 2010 Tundra double cab with the tow package.
Kelvin
Old 10-06-2014, 08:51 PM   #23
Livingston , Texas
Originally Posted by GenXair View Post
Here's my CAT scale tickets. As I stated I didn't weigh the the individual axels of the TV not because I didn't want to but because I didn't know what I was doing. Next time I know how it should done.
The indicated tongue weight is not consistent with the changes in TV GVW.
It appears that some amount of weight was moved from one scale pad to another scale pad between the two weighings.
Do you recall where you were standing when the weighings were made?
Was there anyone else who might have moved from one pad to another?
Ron
Ron Gratz is offline   Reply With Quote
Old 10-06-2014, 09:16 PM   #24
2020 Classic 33
Box Elder , South Dakota
Maybe start over GenX. Do a search on Ron Gratz and his method of weighing. When you drive onto the CAT scales the front axle goes on the forward pad, the read axle goes on the center pad and the trailer on the back pad. As you pull onto the scales drive ahead and as you think you are on the front pad check your rear view side mirror to confirm that the back axle and trailer axles are on their respective pad. WD set the way you normally have it.
Best to do this in camping configuration. Wife, dogs, kids, stuff in the back of the tow vehicle with full tank of gas, trailer with full propane, full water and little in the grey and black tanks.
I jump out of the truck, high five the call button and immediately jump back into the truck with the door open. Tell them that it is a first weigh, private vehicle and wait until they say they are done and to come in. Go in and pay the first weigh ticket. Now comes the fun.
Go back for the first re-weigh. Take the torsion off of the WD system so it is loose. High five the call button and get another weight. Drive off the scales and go pay.
Disconnect the trailer and weigh just the truck. By now the wife, kids and dogs are ready to go home or kill ya. High five the button, get quickly back in the truck and drive off an pay when they are done.
Now if you have a friendly CAT scale operator and they are slow I go in and talk with them before I start this dance. I tell them I would like to do 3 - 4 weights without moving from the scale. I give them my credit card. Now I pull on, and in the case of a ProPride I set it for maybe 5 inches, get a weight. Jump out and move the jacks to 6 inches. Get another weight. Do it again at 7 inches and the fourth time I run the WD down to the loose position. So 4 weights in maybe 10 minutes.
Lots of Back and forth. Key is to get back into the truck after you high five the squawk box. Or at least stand next to the drivers door. Consistency.
Drive off and drop the trailer and do one last weighing with the tow vehicle.
Now go pay and collect your 5-7 tickets. Keep notes of the sequence and label the tickets before you forget.
With a ProPride/Hensley and cooperation of the CAT operator this can be done quickly. With other hitch types might be more difficult but you get the idea.
CAT as you found out charges $10 for the first weigh and $2 for anything subsequent within 24 hours at the same scale.
And here's Ron's calculations in an excel file that you can crunch all of the numbers. This is for my Sierra 2500 and an FC 25 rear bed.
1_Cat Calc Sierra 2500 7-23-14.xlsx
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 10-07-2014, 05:21 AM   #25
Mantua , Ohio
I believe there is a breakaway switch one can buy that has its own battery pack? No trailer battery needed. Or am I dreaming a dreaming again? Jim
Old 10-07-2014, 08:35 AM   #26
2020 Classic 33
Utility trailers have the setup you are talking about Jim. Small battery box usually mounted at the tongue kept charged while hooked up to the tow vehicle.
Gary
NØVPN
Old 10-07-2014, 08:59 AM   #27
2007 23' Safari SE
2016 23' International
Fernandina Beach , Florida
Your hitch is probably good as is, but I would be worried about the rear axle weight. As others have pointed out, you need to weigh front and rear axles on separate scale platforms. Do this with and without the trailer (including WD applied) to get a realistic load estimate. Do it with all passengers and gear loaded. If you are over the rear axle limit (found on the driver's door plate) and you have some slack in the front, then try to apply more WD to the front if possible. If not, unload some of the vehicle load into the rear of the trailer (not people of course).
What you really want to avoid is a blowout or a busted axle in the rear of the TV.
Tomzstream is offline   Reply With Quote
Old 10-07-2014, 09:41 AM   #28
2007 23' Safari SE
I see the Armada sports a 4300 lb RAWR which is plenty generous... and the FAWR is 3400, while the GVWR is somewhat less than the two combined. I'd still check it though. Since it has air leveling, it makes adjusting the WD a bit trickier. Measure hitch height at normal traveling load and auto leveling applied. Then adjust your hitch accordingly. Auto leveling has a tendency to cancel out WD to the front axle if hitch height is off (measured at deflated levels), as it raises the pivot point when it inflates. The net result is more weight on the rear than you would like to see. At least that has been my experience.
Old 10-07-2014, 10:17 AM   #29
Well it looks like I need to head back to the scales again.
Thank you all for your input, advice, & guidance.
Much appreciated.
You all rock.
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 10 03-20-2021 09:12 AM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
Hitch Spring Weight on WDH (Reese vs. Equal-i-zer) AndyPenny Hitches, Couplers & Balls 4 11-09-2007 05:05 PM
