Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 02-01-2017, 03:11 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Take a look before you load the trailer
This video may help those with questions about trailer loading and sway control.
http://www.wimp.com/why-you-should-a...tuff-up-front/
2004 Excursion 4x4
Old 02-01-2017, 05:01 PM   #2
Mantua , Ohio
That video comes around every so often.
Old 02-01-2017, 05:02 PM   #3
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Great video.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 02-03-2017, 08:40 PM   #4
dasams's Avatar
Palm Desert , California
A good example of why your hitch weight should be 10-15% of the weight of your AS.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 02-04-2017, 06:52 AM   #5
2015 30' FB FC Bunk
Ayer , Massachusetts
Good example as to why I'd never tow with a Ford Mustang.
Ted S. is offline   Reply With Quote
New Tires - got Load Range E instead of Load Range D Hyperion 2009-2015 Flying Cloud 49 06-08-2016 06:47 PM
"Warning: If you take the key out of the Cylinder before you install it in the lock deelind Doors & Locks 10 12-14-2014 05:46 PM
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
