Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 07-03-2016, 06:18 AM   #1
2018 28' Tommy Bahama
2017 23' Flying Cloud
2014 16' Sport
New York , New York
Images: 11
Strange Tire Pressure Issue On TV
So a week or so ago I towed our '16 footer about 120 miles on a balmy New England summer eve - 75 degrees . The next day I went to move the van (2014 Honda Ody) and the low tire pressure light was on.
I always carry a bike pump and to my surprise both of the back tires had around 27 lbs of air in them, down from 35. The front tires were fine. These are all relatively new Michelin Premier LTX 103's.
I did find a nail in one of them but the other one seems not to have an issue and hasn't leaked down since I pumped it back up.
I'm trying to figure out if this is just a strange coincidence or if there is an actual issue. The trailer is within the specs for the Honda, I've never heard of air being pushed out of tires, and the nail explains what happened on at least one side.
Thoughts before I go trade it in for an F150 SC EB??
M
mattskav is offline   Reply With Quote
Old 07-03-2016, 06:27 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Do you know what the pressure was when you started towing, other than the warning wasn't on?
Did you go for an oil change recently? Really, they check your tires when they a warmed up and you don't end up with the correct cold temp, which you would have had the next morning.
2019 Ford Expedition Platinum
Old 07-03-2016, 07:09 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You've got two back tires with leaks. You found one, the nail. Or the other one was not pumped up completely. The Airstream has nothing to do with it.
Doug and Cheryl
Old 07-03-2016, 09:06 AM   #4
Rich W's Avatar
I'm In , Kentucky
Sometimes you get air leaks at the rim of the wheel. I had one that had a very slow leak in the winter, not much in the summer. It was very annoying. As soon as the temperature would drop the low air light would come on.
The best way to tell is to take the wheel off, lay it flat and pour a mix of water and dish soap around the rim. There will be bubbles if there is a leak. Make sure to do both sides. If you don't find it there, stand the tire on it's tread and pour the mix along the tread and check for leaks.
If you find one your local tire repair shop will have break it down and sand the rim of the wheel, then apply sealer and air it back up.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 07-03-2016, 01:19 PM   #5
1967 26' Overlander
Spartanburg , South Carolina
I don't trust commercial shops and their worn out tire pressure gauges.
Jacob D is offline   Reply With Quote
Old 07-05-2016, 06:47 PM   #6
Sioux Falls , South Dakota
Your vehicle has a tire pressure monitoring system, and I'm guessing that you have the original tires and sensors. It is possible that one of the sensors has gone bad. Do you have a tire gauge? If so, one of these fine mornings go out and read the tire pressures from your instrument panel. Write them down, and then go out and check the pressures with your gauge. You probably won't come up with the exact same numbers, but they ought to be close and all should be off by the same amount and in the same direction.
As was mentioned above, tire pressures should be set when the tire is cold. You can check them when hot, but NEVER adjust the pressure based on those numbers. About all a hot check will tell you is if you have a low tire.
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Strange Air Conditioner issue Landrum Furnaces, Heaters, Fireplaces & Air Conditioning 15 06-28-2015 10:53 PM
Strange Water Pump Issue ktgsmokey General Repair Forum 10 06-16-2015 11:04 AM
Are you feeling like Sherlock? Strange ignition issue, need advice scottf3334 Mechanics Corner - Engines, Transmission & More... 15 08-28-2009 08:45 PM
