Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 03-10-2007, 12:04 PM   #1
Dan S
Dan S's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Normandy Park , Washington
4 to 7 pin adapter ?
I'm looking at a Toyota Tundra with a 4 pin plug. Can these easily be changed out with an adapter? Or, does it require a run up to the truck battery to enable the trailer battery to charge while towing?
Dan
Dan S is offline   Reply With Quote
Old 03-10-2007, 12:07 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
You will need to run three wires to match the functionality of a seven-pin outlet: Brakes, Charge, and Backup lights.
The brake wire (to a controller) is, IMO, the most important one of the three.
Tom
Old 03-10-2007, 12:12 PM   #3
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 70
The adaptor would allow you to use the lights on your trailer, but would not work for charging or braking or backup lights.
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Old 03-10-2007, 01:20 PM   #4
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
You can't adapt 4 to seven without loosing functions. If you rewire, I would suggest a whole new seven wire harness. It would be easier than trying to retrofit. You can adapt a 7 back to a four if needed.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 03-10-2007, 01:37 PM   #5
Dan S
Dan S's Avatar
So......I would tell the Toyota Dealer who is selling the Tundra to install the new harness and, since I have a Prodigy controller new in the box, to install it all at the same time.
How much is it for a typical harness and install? I want to be prepared when they say" Whoa, that will cost you $xx.xx
Dan
Old 03-10-2007, 01:57 PM   #6
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hi Dan -- Guess I'm surprised they made any Tundras without a 7-pin connector. One of your big questions should be if there's a pigtail plug-in under the dash somewhere (pigtail is the brake controller connector).
Here's some of the parts: Buy All of Your Trailer Parts and Accessories at RJay's Speed Shop!
People have talked about hooking up the brakes -- I should add it would be illegal to tow without brakes (most states if trailer is over 2000#).
Old 03-10-2007, 02:05 PM   #7
Jim Clark
Jim Clark's Avatar
New Orleans , Louisiana
You may want to ask what class the hitch is. The heavier hitches normally have a 7 pin plug.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim,
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 03-10-2007, 02:19 PM   #8
Dan S
Dan S's Avatar
pigtail
Bob,
I have that question into them (pigtail). If it does not, the deal is a no-go as any trailer I get will be at least 20 feet.
Dan
Old 03-10-2007, 02:20 PM   #9
TomW
TomW's Avatar
Normal , Alabama
Images: 77
Start here first
Go with what Jim Clark said first. Between hitch replacement & wiring upgrades you may want to look at a different tow vehicle.
Tom
Old 03-10-2007, 02:31 PM   #10
Dan S
Dan S's Avatar
That is bizarre that it does not have a 7 pin.....I'll call the dealership....which I hate doing. ...."So, what's it going to take to get you to drive this home today?"....shoot me.
Old 03-10-2007, 02:37 PM   #11
TomW
TomW's Avatar
Normal , Alabama
Images: 77
Originally Posted by Dan S
That is bizarre that it does not have a 7 pin ...
Not really. There is no sense in including the wiring if your hitch can not accomodate the load. Class I & Class II (and maybe Class III?) hitches can not tow anything that has a 7 pin connector.
You need to make sure your hitch is rated for towing a heavy load.
Tom
Old 03-10-2007, 04:12 PM   #12
ljmiii
ljmiii's Avatar
Profile:  2006 16' International CCD
New York , New York
I have that question into them (pigtail). If it does not, the deal is a no-go as any trailer I get will be at least 20 feet....
You don't say if the Tundra or Airstream you are looking at is a new one or not. If it is a 2007 then the only ones that don't come with a 7 pin standard are the 4.0L V6s. The max tow capacity of the V6s is 5000 or 5100lbs (long or standard bed).
The new 20' Safari's GVWR is 5000lbs and the 22' is 5600lbs. You need to look at the 4.7L V8 Tundra (max tow capacity 8100-8500lbs) if you want to tow these Airstreams.
If you are looking at older vehicles, then the above may not apply. Pre-2003 Tundras were commonly equipped with 4-pin connectors and older Airstreams weighted substantially less.
enjoy,
leo
ljmiii is offline   Reply With Quote
Old 03-10-2007, 04:24 PM   #13
Dan S
Dan S's Avatar
tundra set up
I'm looking at 2002-2005 Tundras. Most have the seven pin . However, the once vehicle that looked good has the four. I guess I could "make" the dealer install the class 4 hitch and harnes....
The trailers I'm considering are 20 foot Argosys or an older Airstream like a 17 Caravel.
Dan
Old 03-10-2007, 04:33 PM   #14
TomW
TomW's Avatar
Normal , Alabama
Images: 77
Toss it out; see what happens
.. I guess I could "make" the dealer install the class 4 hitch and harnes...
Like you said, ...."So, what's it going to take to get you to drive this home today?"....
Tom
7 pin connector adapter gparker Electrical - Systems, Generators, Batteries & Solar 2 12-16-2006 07:11 PM
1978 24ft Argosy brakes juel Brakes & Brake Controllers 6 10-31-2004 05:14 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 04:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 11:26 AM
Adapter / Electric from garage? bkpine Electrical - Systems, Generators, Batteries & Solar 8 08-13-2002 09:22 PM
test
