Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-06-2010, 01:25 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Propane tank clamp/bracket
My bracket that screws down on to the top of the propane tanks and holds them in place is cracked. Anyone have a spare they want to sell?
Dan
Seattle, WA
Dan S is offline   Reply With Quote
Old 07-06-2010, 01:37 PM   #2
Try craigslist in Santa Cruz, CA. Someone was trying to off one for the last few weeks.
Rich the Viking
VIKING is offline   Reply With Quote
Old 07-06-2010, 02:30 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Is this the one you need? Gas bottle hold-down bracket 101796 [101796] - $29.95 : ODMRV , Out-of-Doors Mart
There's also one without the regulator bracket: http://odmrv.com/catalog/index.php?m...roducts_id=276
Vaughan
Old 07-07-2010, 01:30 PM   #4
Dan S's Avatar
1975 Argosy 26
That's it.
Dan
Old 07-17-2010, 09:51 AM   #5
Alliesargosy's Avatar
1978 Argosy 27
Bay Area , California
I need the same thing - is this a common failure part?
Alliesargosy is offline   Reply With Quote
Old 07-17-2010, 09:59 AM   #6
Yes.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-17-2010, 11:11 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
They have used a high flow aluminum alloy which is good for easy sand casting but it contains too much silica in the formula which make it very strong but it has almost none of the elongation found in other aluminum alloys. All these brackets are subject to cracks, if you tighten them or they are subject to sudden shock. There is no easy answer to this problem and I am not sure whether the new brackets are made from a more appropriate alloy. Mine cracked also.
Old 07-17-2010, 11:47 AM   #8
My old Safari has a steel one. That's what was listed for sale in Santa Cruz craigslist recently, also. I wouldn't trust an aluminum one.
Rich the Viking
Awning Clamp Assembly airtime Awnings 5 06-20-2018 05:23 PM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
Getting the most from your propane tank ArveeBob Base Camp 0 09-15-2009 01:38 PM
Propane tank charlief1317 Airstream Motorhome Forums 14 01-04-2003 08:00 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
