Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1984 - 1989 Sovereign
Old 10-09-2016, 06:29 PM   #1
1987 25' Sovereign
Richland , Washington
Lights - Inside and Out
I just replaced my original converter in my 25' 1987 Sovereign. While checking out the electrics I noticed that my OEM internal lights draw 1.5 amps each! What have you all used and recommend for replacement LEDs? Thanks!
JohnBarth is offline   Reply With Quote
Old 10-09-2016, 06:57 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Owner is a member here. Excellant company to do business with.
http://led4rv.com/index.php?main_page=index&cPath=15
MICHAEL
Old 10-09-2016, 07:33 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I replaced some of the high usage light bulbs with LEDs in our 86. I replaced exterior marker lights and tail lights with LEDs for improved visibility. LEDs are clearly the way of the future. They require just a fraction of the energy of an incidence bulb.
David
Old 10-24-2016, 10:29 PM   #4
1987 25' Sovereign
I just replaced all the interior bulbs and the outside floodlight bulbs with these warm white LED's. With the covers on they look just like the old ones in brightness and color. And each bulb only draws 0.23 DC amps, or a reduction of 85%!
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 10:05 AM
for sale parting out an entire airstream inside and out jazzy13 Airstream Classifieds 3 09-01-2015 03:31 PM
Switching out inside lights to LED Idaho air Lights - Interior & Exterior 4 05-29-2012 10:52 PM
Lights not working, inside and out - '78 Ambassador qratio Lights - Interior & Exterior 2 10-05-2010 09:37 PM
Removing Vinyl and Glue-Inside or Out Leya Costa Clearcoat, Exterior Paint & Trim 4 07-07-2008 12:14 PM
