Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1984 - 1989 Sovereign
Old 10-28-2015, 09:00 PM   #1
twm
danville , California
Rear-end closet...concerned about weight?
hi all. I am new to A/S forum. I am planning on purchasing a 31' Airstream to live in full time in the coming year. My interior design plans are coming together. I want to gut a 1984??? Sovereign. I would like to have a Closet & Drawer unit covering the entire back end of the trailer (Floor to Ceiling and wall to wall). Question: does anyone know if this could be a weight issue for the trailer frame? Is there any useful data source to tell me if the trailer end has a weight limit? Any response welcome. Thanks. twm Danville, CA
twm is offline   Reply With Quote
Old 10-28-2015, 09:10 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
You can find some info on Airstream's archives here: http://www.airstream.com/wp-content/...dacd35e8bf.jpg
GVWR will be dependent largely on the axles - if they're 3600# each, your max weight is 7200# (the information should be on the sticker on the trailer).
Putting all that weight (assuming you fill it with clothes) in the very rear could be problematic in terms of balanced weight for the tongue (you could conceivably lift too much weight off the tongue which you want to be 10-15% of the weight of the loaded trailer (e.g. - if 6,000# loaded for camping, you want 600-900# of tongue weight).
Others here will have lots more info - hope that's a helpful start....
Old 10-28-2015, 09:57 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Unusually heavy weight at the rear (or front) will make it very difficult to control any sway movements. When swinging out, the weight makes the rear of the trailer move farther to the side than normal before controlled, then even farther to the side in the other direction. The heavy weight is increasingly more difficult to stop. A dangerous sway condition is much more likely.
Our Airstream Owners Manual warns agains heady loads on the rear of front of the trailer. They build them with the heavy appliances, kitchens, and storage tanks over on near the trailer axles.
Doug and Cheryl
Newb concerned about bottom half of Argosy 30 ft 77 model. jrusargosy Repairing/Replacing Floor &/or Frame 1 10-08-2011 08:35 AM
2008 Airstream losing rivets, should i be concerned? whacksplat Ribs, Skins & Rivets 2 04-02-2010 11:50 AM
need help with concerned husband new2rving General Repair Forum 7 10-04-2004 07:29 PM
New trailer isn't level, L-R concerned about my axles Dave Jenkins Axles 17 08-24-2004 02:38 PM
