RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-19-2015, 07:20 PM   #1
Tiger Tail's Avatar
1986 31' Sovereign
Jacksonville , Florida
Fuse makes clicking noise
Fuse makes clicking noise, and our Radio turns on and off, on and off. I know my battery is bad but this is happening while the AC inverter is on. This is a new one on me since I don't really understand the resetting fuses. Anyone seen this and corrected it?
Tiger Tail is offline   Reply With Quote
Old 12-19-2015, 07:34 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
It sounds like a auto resetting circuit breaker instead of a fuse to me...Regardless, I suspect you have a short. The short trips the circuit breaker and cuts the power. The circuit breaker cools resets and the power comes back on.
CRH is offline   Reply With Quote
Old 12-19-2015, 07:52 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Small silver can a bit larger than the standard mini fuse? If so it's a common mini breaker.
Most likely short circuit. The speed at which it cycles indicates how bad the short is. If it takes a while to reset it's either just at it's amperage range or is begining to fail.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 12-19-2015, 09:46 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Replace it with one of the same size. If the clicking continues you are drawing too much current through that circuit. If not it was a weak breaker.
If it clicks with the new breaker look at the loads on the circuit to see if you have added a new load that was not considered when built. If no new load you may have a short in the wiring, not that likely but it is possible.
2004 Excursion 4x4
Old 12-20-2015, 12:25 PM   #5
jackson center , Ohio
What type/model of Airstream is this on?
What type of Airstream is this on? Is it coming from where the blade fuses are locate
Schu is offline   Reply With Quote
Old 12-21-2015, 07:16 AM   #6
Tiger Tail's Avatar
1986 31' Sovereign
Well its fixed. I miss stated,they are not fuses they are auto reseting breakers. I put the shower wall back in and the exposed wires for the ceiling light got stuck together. Easy fix. But I sure like how this forum rallies to help a fella Airstream error out! Thanks guys Merry Christmas and Happy Holidays to you all.
Clicking noise-converter or? m.nolte Batteries, Univolts, Converters & Inverters 2 02-18-2015 12:32 PM
clicking noise nancyo Sprinter and B-van Forum 12 06-30-2014 09:14 AM
Periodic clicking noise boondocking with gas Hankster Refrigerators 5 09-27-2012 08:17 PM
A/C clicking noise Goldeneye Furnaces, Heaters, Fireplaces & Air Conditioning 14 05-15-2009 12:34 PM
Clicking noise after installing Tekonsha Envoy in 2008 VW Touareg ericwarren Brakes & Brake Controllers 1 08-01-2008 09:08 PM
