Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 1997 - 2004 Bambi
Old 09-13-2016, 12:50 PM   #1
2004 16' International CCD
encino , California
help with solar in 2004 16ccd
ive exhuasted all the threads I can, Im looking to put 80 to 100 watt solar on top, I've found pre wire under street side seat at battery terminal, I can't find wires in closet or in ceiling??? I've taken off fantastic housing inside and dug around to no avail.... any help greatly appreciated.
thanks
tim
resedaheat is offline   Reply With Quote
Old 09-13-2016, 01:31 PM   #2
2007 22' International CCD
I'd run new, much bigger wires, personally. Had the same problem and wisely, it turned out, gave up quickly.
Old 09-19-2016, 01:06 PM   #3
encino , California
Ive given up for now but still want to add an 80w zamp thin line panel to the roof, I've found wires at terminal under street side seat and wires running up inside wire harness in closet with no break in them, can anyone tell me where they might end in ceiling to access them? final option is running new lines, in which case does anyone know the best place to drill into ceiling to run them down the wall?
Phone Jack is Wack! 16CCD 2004 MaShep 1997 - 2004 Bambi 17 12-04-2004 09:31 PM
16CCD owners frozen chosen 1997 - 2004 Bambi 99 11-09-2004 06:03 AM
Mice...entry locations in my new 16CCD sdairstream 1997 - 2004 Bambi 5 10-31-2004 09:46 AM
16CCD Shakedown cruise frozen chosen 1997 - 2004 Bambi 1 05-16-2004 09:03 PM
Need 16CCD Forum frozen chosen 1997 - 2004 Bambi 3 08-02-2003 08:05 PM
