Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1960 - 1965 Safari
Old 05-02-2018, 06:40 PM   #1
1965 22' Safari
California , Kentucky
AC location
Where specifically does a new AC unit go on my 65 Safari. It was manufactured in OH and has a 12/2 w ground taped and marked coming out of rear wall. Also did AS install a drain line for future or what. Any help,appreciated getting warmer in ATL
RiverRat is offline   Reply With Quote
Old 07-11-2018, 05:43 PM   #2
StPierre's Avatar
1965 22' Safari
Rescue , California
River Rat I just installed a Pinguin II on my 65 Safari , at the center roof vent. You will find the 120 vac wire there, also mine had a 14/2 wire that I think was for a thermostat if used. Also I replaced the breaker box to add another 20 amp breaker. Mine did not have a drain installed ,but I was able to run one through the cabinet over the refer. The job took me less than a week , and half a day to build a scaffold above the trailer. Good luck any thing I can help you with let me know
The St Pierre's
StPierre is offline   Reply With Quote
Old 07-12-2018, 06:23 AM   #3
1965 22' Safari
Ac location
StPierre,
Thank you for the info. I have already installed my ac in the same location. The wires were behind the roof rib so I drilled out the ceiling rivets and was able to snag the two wires. Tore up the 14/2 in the process and spent many hours tracing it to the front cabinet above the refrigerator. You are correct it was for a remote thermostat. I ran the drain through the cabinets to the rear and a happy cooler camper I am.
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
P30 VIN location dienst1 Airstream Motorhome Forums 5 01-14-2003 03:11 PM
"Off Topic" forum location... Andy R Forum Admin, News and Member Account Info 4 03-26-2002 10:10 PM
