The repair manual would have you protect the shell, slide a thin putty knife down behind the bezel and knock the cast mountings pins off. Reassembly is by drilling holes in the recess around the bezel and securing with blue painted rivets.
That being said I was able to remove and recondition the light cans and sockets without removing the bezel.
I believe there are some threads on replacing the cans with LED ones. You will loose the fiber optic indicator however.
Good Luck,
Tom
