07-13-2012, 07:03 AM
1987 32' Excella
Middlesex
, North Carolina
Cleaning exterior of '86 Excella
Can someone tell us the best way to clean the exterior of our "new" trailor? It needs a good scrubbing so to say but not sure of what to use on the exterior finish. In our manual it calls for a certain brand, but will another product do just as well?
07-13-2012, 08:54 AM
1981 31' Excella II
New Market
, Alabama
If there is alot of milldew you will have to really scrub it. I expect your roof has lost the clear coat so you could resort to something like scotch bright. I would test in a small area first on the roof where it can't be seen. On the sides, I would use dish soap and water and a rag. I am assuming your clear coat is already gone for the most part. On a new trailer, with good clear coat I would not use the scotch bright. Do not try to climb on the end caps. They are soft and will collapse. Start gentle and work your way up to something more aggressive. A Dobie pad would be something to try. They are not real aggresive but they do a good job on built up crud.
Perry
07-13-2012, 09:24 AM
1987 32' Excella
Middlesex
, North Carolina
Thank you Perry! The clear coat is in better shape than you would think and there is some mildew. We will start at the top and work our way down as you suggest. We appreciate your info and time.
07-13-2012, 09:43 AM
1964 17' Bambi II
Schererville
, Indiana
I used Amazing Orange from the dollar store to clean up my trailer. It's really amazing! Cut through the crud on the top like nothing.
Becky
1964 Bambi II
1988 Avion 32S
07-13-2012, 02:35 PM
1987 32' Excella
Middlesex
, North Carolina
Becky,
Thank you! I am going to the dollar store then, and hope we get the same results. We are closer to pulling it out of the shop, from all the under belly and interior work we have done on her. Exterior and awnings to get cleaned next.
May I ask if either of you have replaced the drapes? The blinds remain in the windows, however the drapes were removed by previous owner. I need to solve that issue as well. I have a quote from JPA Drapes Inc. for new ones. Not sure what to do there.
Renee
Renee
07-13-2012, 02:54 PM
Ottawa
, ON
I used Dawn dish detergent, a long-handled soft-bristled brush, and Henri shone like the star he is.
As in all cleaning, start gently and work up slowly to more harsh methods. The brush and lukewarm water got all the green grunge off of my TT.
Careful with the Scotchbright, if the clear coat is still there (like on most of Henri) it will dull severely if Scotchbright is used. Don't ask how I know...
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
07-13-2012, 03:01 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
trick is to use a brush and scrub the mildew. I used a stiff toothbrush on the rivet dimples. I would not use anything metallic or scratchy at all. Cleaner and a good scrub will get it clean. When you do get it clean I like Envy waterless cleaner every once in a while.
07-13-2012, 03:19 PM
1987 32' Excella
Middlesex
, North Carolina
Thanks to all the great advise you have shared with us
07-13-2012, 03:24 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
It will significantly rough up the aluminum surface if there is not clear coat too. Good for prepping a surface for paint or maybe an engine head for a gasket, not so much for anything where appearance is important.
Vaughan
07-15-2012, 06:14 AM
1964 17' Bambi II
Schererville
, Indiana
Originally Posted by Fatboy99
Becky,
Renee
Renee
I had all of the drapes replaced in my '86 Sovereign by a lady here on this forum named "Silver Threads". I bought the fabric & shipped it to her. They are really nice!
Becky
1964 Bambi II
1988 Avion 32S
07-15-2012, 06:49 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
You might also want to clean the sticky surface off the inside of the trailer. Krud-cutter works pretty well. The sticky comes from the plastic coating. I use Krud cutter and then wash it with Simple Green and then dry it with a towel. Have done 2 of the mid 80's Excellas this way and it worked pretty well.
07-15-2012, 08:39 PM
1964 17' Bambi II
Schererville
, Indiana
And after you've gotten the sticky off, put a coat of Future floor wax over it & it won't come back again! (else it will in a few years)
Becky
1964 Bambi II
1988 Avion 32S
07-16-2012, 07:42 AM
1987 32' Excella
Middlesex
, North Carolina
Wow, practice does make for perfect information to share here. I did have that sticky problem, and used similar products like above. However I did not seal it, so I will use the floor wax cure.
Thanks again!!!!!!!!!
