Originally Posted by bwaysteve
Does anyone have a closeup shot of the curbside access door and the rear access door.The PO put sheets of aluminum in place of the doors.They look ok but the whole piece comes out when open.Rear is screwed in at 4 points and the cs door has a hardware store lock hinge to keep it closed.Are both of these doors originally hinged at the tops to open them? I have no hardware for these if they do.Steve
Steve.
The access doors on a 65, slipped into a slot at the top of the frame, and were latched at the bottom.
No hinges were used.
How about a couple of photo's?
If there is any rear end separation, usually, the rear access door frame, pulls apart at the bottom, which allows the door to fall out.
Check each door frame (the part that is riveted into the shell) for anything that may seem strange.
Andy 8.5
