08-06-2019, 12:25 PM
#81
Jeffersonville
, Kentucky
Yes, much had been done.
I will see if I can do some update pictures.
It was a mad rush to have a livable camper for the international meet in Doswell. Worked till the last minute. First time it was on the road was when we pulled out for VA.
We slept on cots and had no kitchen, but do have electric, ac, and a bathroom
08-06-2019, 01:47 PM
#82
Jeffersonville
, Kentucky
accompanying pictures will follow soon
so, I had to be ready for WBCCI international.
We signed up a year in advance. Plenty of time..... lol
Rockwool Insulation in walls
inner skins washed
inner skins installed
inner skins painted
additional pieces of aluminum below end caps to fill in where the old fiberglass used to cover
floor ( engineered plank ) installed
brakes wired
new wheels and tires
electric jack installed
Maxx Fans installed and wired
ceiling lights installed
outlets installed 110v and usb
Bathroom
framed closet
Closet is over top of the hot water tank
Also houses all breakers, fuses, and readouts.
Converter and EMS are on the floor ( will be under the bed )
24x32 tub. on platform
framed with lumber
skinned with board, painted with aqua shield
corners have bent aluminum and then overlapped with sheet of aluminum
rear sink/vanity framed up.
Toilet placed and black tank installed under floor
Batteries installed in a slide out tray.
Fresh tank up front in original location
PEX and plumbing done.
wasted valves installed and plumbed
Black tank temporary covered for trip ( no insulation )
08-06-2019, 02:02 PM
#83
Jeffersonville
, Kentucky
a temporary kitchen food prep table was made
new seals on some windows, but most left with old seals due to time.
We did get it washed in the driveway
only leak at this time was the rear hatch
I played with it to tighten the gap
Guessed at the hitch setup.
Took the trip.
4 hrs to our first stop
4 more into Doswell
Towed great.
Brakes worked.
Toilet and shower
Plumbing works
all electric works
Old AC worked
so far, only 4 issues.
During a rain,
rear hatch still leaking a little bit into the channel.
had a leak from the ceiling.
It was coming through a pop rivet that was in the ceiling panel holding the maxfan trim
I think it is coming from probably the sky light and then running down the ceiling panel to the rivet. ( I never resealed around the sky light )
3rd issue was a scratch on the new floor.
I cannot figure out how it happened. However, it is in an area that will be covered by the bed.
4th, the engineered floor that I picked because it should NOT shrink or expand. Must have shrunk. it started to gap on a few of the short ends.
( 94% of the gapping is gone now that it is back in the barn )
At this point, I still have access to the ends of the boards if I take out the fresh water tank. I have silicone caulk around the parameter to fill any gap between the wall and planks.
So, I plan to run the AC for a while and get it cold, and then hammer the ends to make it tight again.
Then, I may just secure the boards in place at the far ends with a screw. And cross my fingers that it does not expand much when I turn off the AC and it warms up.
These boards should not have done this ( at least this much ) maybe they just "moved" and did not contract. ?? dont know
So, the trip was great. So glad that everything functioned.
08-06-2019, 02:36 PM
#84
1966 22' Safari
Fredericksburg
Glad to hear all went well. Everyone has a punch list after the first few ventures. Yours seem fairly minor. Good luck and keep up the good work.
09-23-2019, 12:05 PM
#85
Jeffersonville
, Kentucky
During the whirlwind to get ready for international, here are some pics of what was done. I did not take pictures along the way.
General Pics
09-23-2019, 12:09 PM
#86
Jeffersonville
, Kentucky
The bath
Currently still just framed up.
The closet houses the breaker panel and switches.
The Shower was framed, paneled, water proof painted.
Aluminum "angle" in the corners. Then walled will aluminum.
Will be adding a drawer under the sink.
09-23-2019, 12:10 PM
#87
Jeffersonville
, Kentucky
Bulkhead panel dry fit
09-23-2019, 12:15 PM
#88
Jeffersonville
, Kentucky
Latest Project.
I will be taking more pics as I make the second one.
Putting in twin beds.
So I build this bed frame to maximize storage.
The drawers are build to miss the plumbing and electronics that will be behind them. Ball bearing full extension slides.
And I got to learn to make dove tail drawer boxes.
Note ( the drawer fronts are still to be added )
I used 1/2" plywood for the drawer box sides.
