Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 06-08-2015, 10:29 AM   #1
2007 25' Safari FB SE
Scottsdale , Arizona
Water Leaking at Wheel Well when water is hooked up
I've only been an airstream owner for a few months and have been dry camping until this weekend. We have a 2007 25' Safari FB. This weekend we had full hookup at an RV park and noticed that whenever we use the water it appears to be slowly leaking near the wheel well by the water hookup on the trailer. When the water hose is connected but no water is being used on the inside it does not appear to be dripping water. The last few times we used the trailer with full water tanks but no hookups this did not happen. Is this something to be concerned about? All suggestions are helpful. Thank you!
Lauren25 is offline   Reply With Quote
Old 06-08-2015, 10:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
YES very defiantly.
Not sure I can think of a source of water that would manifest itself only when you are drawing city water. But the issue is you have a leak and a leak will destroy to floor in time.
Rereading your comment it may be a leak in the gray water drain system. That would be time sensitive to using the water. Check any drain in that area while using water.
2004 Excursion 4x4
Old 06-08-2015, 10:58 AM   #3
1978 Argosy 24
MooreHaven , Florida
On our Argosy the condensate water from the A/C drips out just at the front of the wheel well.Is it possible that is what you are seeing? Ours drips out of a grey tube.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 06-08-2015, 10:59 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I'm going to make a wild ass guess that your built in pressure regulator is defective. If I'm correct, that's a fairly easy fix as the regulator is part of the city water connection to the trailer.
This is the part I am referring to:
Water pressure regulator
Bob Martel
WBCCI# 5766
Old 06-08-2015, 11:01 AM   #5
Merkel , Texas
If you are using your air conditioner, the drain line for it empties in that area. Maybe the timing is coincidental with water being used. Just another suggestion for you to check on. Good luck in tracing the origin down,
afneill is offline   Reply With Quote
Old 06-08-2015, 11:07 AM   #6
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Haines , Oregon
Is there a chance that you have a drain valve that is ever so slightly open? You probably have the tank drain between the wheels, and two line drain valves under the trailer. The latter two are the first place I'd check.
Edit: just read that it's only when water is being used. I don't think my answer is correct for this, but I'd still check.
Old 06-08-2015, 11:30 AM   #7
2006 19' Safari SE
Hayes , Virginia
My "leak" is the condensation from the air conditioner. It's an important drain to keep clean from your AC.
mocus is offline   Reply With Quote
Old 06-08-2015, 12:12 PM   #8
1979 23' Safari
Wayland , New York
I'll third that it's probably the ac drain, if you've been dry camping until now you probably haven't been using it. Now that it's warmer and you've got hookups you're probably using the ac. Drain typically comes out in that area. Take a look under there and see if it's coming out of a tube coming through the belly pan. If it is you're good to go.
Old 06-08-2015, 07:36 PM   #9
Thank you for all the info. I will check out the AC condensation and hope that's the water that we see...not a real "leak". Thanks for all of your help.
Old 06-08-2015, 08:22 PM   #10
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Had the same issue and it was a crack at the water inlet on the inside. You can get at it through the back of the closet to see if it is leaking and check the back flow preventer as well.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-09-2015, 10:21 AM   #11
1986 34.5' Airstream 345
Alliance , Ohio
Is it near your water heater? I had a leak on my water heater tank that was only noticeable when hooked up to outside water. Apparently the pressure was higher than from my on board water pump.
mehes is offline   Reply With Quote
Old 06-09-2015, 11:49 AM   #12
Livingston , Texas
Yesterday when I was flushing tanks I noticed a leak onto the tire and nothing strikes fear like the possibility of a water leak. We had just been to Jackson Center so I was super bummed that we had a leak to deal with - luckily but unbeknown to me - hubby had it checked out and found it was the condensation from the A/C. Hurrah! Still makes you wonder why they designed it to drip on tire - I'm no expert.
Seemore2006 is offline   Reply With Quote
Old 06-09-2015, 01:14 PM   #13
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Thanks for all the Ideas - I've had this leek since I've had my AS and it's driven me crazy!
Mine's a '75 - 31', older than yours, but same problem.
Mine's not AC, since I mostly don't go places I have to use it.
Thanks for the Idea's - I going to check them all out again - I'm almost ready to trade AS's to get rid of the problem - not really.
Silver Hawk is offline   Reply With Quote
Old 06-09-2015, 02:18 PM   #14
Rhino33's Avatar
Versailles , Indiana
We noticed a tiny leak between our curb side wheels - while using city water, but not the A/C. I think our A/C drain is on the street side, so we're not sure what could be there to leak. No drips from the fresh water lines from the kitchen or the bath, so this seems to be a big mystery, but one I am concerned about...
Robb, Jenn & The Brown Dog (Dex)
Maizie, The Black Dog, May You Rest Peacefully
2005 Safari 25
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 06-09-2015, 02:21 PM   #15
Skater's Avatar
1995 30' Excella
Bowie , Maryland
A low point drain dripping?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-09-2015, 02:27 PM   #16
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I don't think your guess is too wild ass. I betting that is exactly what it is...bad water inlet/regulator. I know because the same thing happened to me recently and replacing it fixed the problem!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 06-09-2015, 02:54 PM   #17
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Our 2005 Safari started dripping water from the belly pan directly under the city water hose connection , removed the little wooden cover that's behind the rear dinette back cushion to access the space under the bathroom sink which is where the city water connection enters the trailer , after much contortion and gnashing of teeth , the leak was defiantly in the fitting that connects the inside water lines to the nifty little chrome water hose connector . There is a pretty good size diameter plastic nut encircling the water line at this point , so Managed to get a pair of channel locks on the nut "with more extreme difficulty" and tighten this plastic nut . This hail mary fix seems to have fixed the problem that should have never occurred had the fixture been properly installed at the factory . one of many , but this occurred two or three years back and is still leak free . hope this helps :-)
PS . this trailer has no regulator behind the water inlet
dannydimitt is offline   Reply With Quote
Old 06-10-2015, 11:52 PM   #18
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Also, check to see if it is the drain for your refrigerator condenser. That is where my 25' FB drains.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 12-28-2017, 08:34 PM   #19
2015 25' Flying Cloud
Euless , Texas
I have had this leak in my 25 and it is not the AC drain. It comes out at the bottom end of the fender trim. I just felt today and there is another drain hose running along the wheel trim. There are two drain hoses at the curb front wheel. This is strange. The back AC has the drain at the rear wheel. Help with wheel drain hose.
Beaerman is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 86 06-08-2023 08:54 AM
1974 safari water leak when hooked to town water Jasper_pilot 1974 - 1979 Safari 8 06-09-2007 02:18 PM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 12:46 PM
